code 212 , help !
Old Oct 20, 2018 | 07:11 AM
BigDan1's Avatar
BigDan1
code 212 , help !
Vehicle : 196 FORD E350 460 EFI
I just rebuilted the engine with some mods : bored .030 ,9,2cr, ported F3TE heads & intake , lunati tow cam & kit , 28lbs bosch injectors, 400hp/500ftpds torque ....
Since I reinstalled the engine ,I keep getting code 212 .... Loss of ignition diagnostic monitor/SPOUT circuit grounded ....
The engine starts fine , idles low , but if I put it in gear will stabilize, when warmed up , idles at 800 rpm stable ,,,,,
I put it in gear , drive , it will go great for a while and suddenly it bucks on coasting and even more on smooth accell ,,,,,But , if I floor it it will accelerate normally ......and then the check engine appears ....back home : code 212 .....the worst is it does not do it all the time ....intermittent .
For now , I cleaned all the connectors with apropriate cleaner & compressed air , checked the pink wire from spout to ICM ,
I noticed that my ICM is gray ( on left inner fender ) seems original : p/n: E7DF-12A297-A2A
on all subjects that i read it says it should be black ??????
before the rebuild, I never had any code .....I`m lost ! passed too many hours on that project , i`m pooped ! ( 66 years young )
Thanks for your help ,
Dan
Old Oct 20, 2018 | 11:13 AM
BigDan1's Avatar
BigDan1
This morning:
verified continuity between port 4 ( PCM ) and ICM w/pk wire = ,2 ohms = good
verified continuity between port 36 ( PCM ) and ICM pk wire ( spout circuit ) = ,2 ohms =good
what else ?
Dan
Old Oct 20, 2018 | 12:14 PM
BigDan1's Avatar
BigDan1
this is what my setup looks like ...... I hope the aluminium shield does not hide a resistor like the old style ICM ,,,,,,ten id need a gray one
Old Oct 27, 2018 | 01:12 PM
BigDan1's Avatar
BigDan1
for the sole purpose of helping others
installed the black ICM ( instead of the gray one ) , solved the 212 code ,,,,
Old Oct 28, 2018 | 03:01 AM
Skitter302's Avatar
Skitter302
if you have a MAF truck you need the black TFI ICM.
BigDan1
Nov 14, 2018 07:33 PM
2005f-150
Feb 7, 2012 05:23 PM
bremen242
Aug 25, 2004 09:44 PM
jamesbell
1983 - 2012 Ranger & B-Series
Apr 1, 2004 09:22 PM
Adrienc9
Mar 30, 2004 07:09 AM
