Onan gen set?
Old Oct 18, 2018 | 06:27 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Onan gen set?
My 5.5 k gen set just stopped after running for an hr. It has 12 hrs on it has spark, power to fuel pump, fed from 20 gallon tank in back. Wondering what you guys think happened?
Old Oct 18, 2018 | 06:28 PM
seville009's Avatar
seville009
Low oil shut off maybe?
Old Oct 18, 2018 | 06:43 PM
william_04_x's Avatar
william_04_x
Carb, or fuel injected? You should have a code flashing on the interior panel, or genset start button.
Old Oct 18, 2018 | 09:36 PM
Desert Don's Avatar
Desert Don
^^^^^^^^^ Here you go. When it shut down, there should be a light that blinks in sequence telling you what the code is. There should be a book on the genny, or maybe online info to tell you why it shut down.
Old Oct 18, 2018 | 09:52 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Its carb, no blinking light, and 2017 gen set
Old Oct 19, 2018 | 06:47 AM
Desert Don's Avatar
Desert Don
When you press the “PRIME” button before starting the genny, does the light next to the switch light up, indicating that the electric fuel pump is running? If so, that same light should blink a series of blinks indicating the code.
Mine is carbed, 2013 model and if it shuts down the light next to the start-stop button will blink the code indicating the reason for the shut down.
last summer in 100*F heat, I was running both AC units and the genny would run for like 30 minutes, then just shut down. The blinking code indicated “Shut down without operator command” (from the troubleshooting page in the manual). I concluded that it was vaporlocking with that much load on it; shut one AC unit off and it ran fine.
Old Oct 19, 2018 | 10:21 AM
HRTKD's Avatar
HRTKD
I have the service manual for the 5.5 generator in my trailer. If you get the blink codes I can tell you what they mean.
Old Oct 20, 2018 | 06:42 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
code 36, i have spark and power to the fuel pump when cranking.
Should the fuel pump make noise when powered? It started for 30
seconds when we got home, and died.
Old Oct 20, 2018 | 10:02 PM
HRTKD's Avatar
HRTKD
I don't have my manual with me but I think a code 36 indicates there is a fault in the control board. Check all connections to the battery. No corrosion, loose connections, etc.
The fuel pump should be heard while priming. After my generator starts I can't hear the pump.
Old Oct 21, 2018 | 09:24 AM
Desert Don's Avatar
Desert Don
Code 36 is the code for “Shut down without operator command”; so it coukld be bad fuel pump, clogged fuel filter, bad carburetor, or whatever. Good luck.
i found out the hard way that one needs to run the genny’s about once monthly to keep the carb operating. They don’t like stale gas, and there are no re-build kits for the carb......just new carburetors at $250-300!!!! Even with Sta-bil in the gas.
Old Oct 21, 2018 | 05:33 PM
william_04_x
I've had a carb go bad also. I drain the fuel bowl after every outing now. Been fine for 10 years.
Old Oct 21, 2018 | 07:09 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Bad fuel pump after 12 hrs! Hopefully the airtex brand will last longer...
Thanks for all the help/quick reply's!
Old Oct 22, 2018 | 05:46 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
Before starting I wasn't priming the generator,
that may have caused the death of the pump.
I didn't realize that the switch could be pressed down to prime.
Old Oct 22, 2018 | 11:46 AM
HRTKD's Avatar
HRTKD
My Onan 5.5 has 700+ hours on it and I believe the pump is the original. At the very least, it's OEM. I know this only because I had to look at it carefully to see if there was a filter on the pump end of the fuel line. My pump is located right next to the fuel tank which is at the back of the trailer while the generator is at the front of the trailer. There is no filter at the pump end. Apparently, Onan may have had two filters in the system at some point and deprecated one of the filter locations. There's only one now and it is right at the carburetor on mine. What worries me is the the pump is mounted right behind the wheel well (rearward of the wheel well, not inboard). If the tire lets loose the pump is going to get it.
Old Oct 22, 2018 | 07:53 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
mine is up front under the generator with the filter screwed into the end of it.
In a bind an auto store should have a low volume pump ,and a person could
install it line by cutting the rubber hose, at least on my set up.
