64 292 Pulled valve covers
Old Oct 18, 2018 | 06:13 PM
Light Doug's Avatar
Light Doug
Hi! Is this normal to see when removing valve covers on 64 292 f100? Very greasy. Sorry on the picture I cant figure how to post it. Thanks
Old Oct 18, 2018 | 06:24 PM
RangerMercMan's Avatar
RangerMercMan
You have no pictures for us to scrutinize. I am assuming it is a lot of sludge and the answer is no if that is the case.
Old Oct 18, 2018 | 06:28 PM
Light Doug's Avatar
Light Doug
What would cause the sludge?
Old Oct 18, 2018 | 06:38 PM
Light Doug's Avatar
Light Doug
Old Oct 18, 2018 | 06:51 PM
Tedster9's Avatar
Tedster9
Y Blocks had trouble with upper oiling "back in the day". The oil gallery that feeds each valve train makes a dog leg between the block and each head, sometimes things would get sludged up. At least, it's not bone dry up there, then you know there's trouble. Additional factors were non-detergent motor oil, infrequent oil changes, leaded gasoline, short trips, out of tune, defective, missing, or wrong temperature thermostat etc.
What you might do is remove each valve train rocker assembly, and clean out the rocker tubes of sludge &c, and inspect them for scoring and galling on the underside. That's where the wear occurs. It's sort of a pressurized system of oil through the rocker tubes and around the rocker arms, and return oil then diverted to lubricate the timing chain & distributor at either end. Replacement rocker shafts aren't real expensive and probably a better idea yet. The rocker arms can get spendy.
While the rocker assemblies are removed crank the engine over with the starter and check to see that both heads have good oil flow. Modern detergent oils and fuel are much less prone to sludge. If everything gets cleaned up good and tuned up good, it will stay real clean up there.
Old Oct 18, 2018 | 06:58 PM
User 71024's Avatar
User 71024
What you are seeing was normal in the 60's because the oil wasn't all that good. Most of the engines we took apart that didn't get regular oil changes would look like that. Keep in mind there are millions of people out there that think you never have to change your oil, just add it when it's low. So if that truck sat for a lot of years it may be normal for an engine that didn't get taken care of. I'd pull the engine and drop the pan and give it a good douching. Then make sure you have good oil flow when you put it back together..
Light Doug's Avatar
Light Doug
Thank You! Now it looks like this.
Old Oct 18, 2018 | 07:14 PM
Light Doug's Avatar
Light Doug
Was it a good idea to clean it without taking it apart? Would the old grease be a benefit to leave it? Thanks
Old Oct 18, 2018 | 07:23 PM
Tedster9's Avatar
Tedster9
The rocker shafts are hollow, with a drilled hole for each rocker arm. If they are sludged up the wear is very rapid without lubrication getting to the rocker arms.
Old Oct 18, 2018 | 07:27 PM
Light Doug's Avatar
Light Doug
Hi! Did cleaning the sludge in the area make it worse or did the old sludge help to keep it lubed? Thanks
Old Oct 18, 2018 | 08:30 PM
Tedster9's Avatar
Tedster9
No, the sludge does not help anything.
Old Oct 19, 2018 | 02:49 PM
User 71024's Avatar
User 71024
at this point you need to make sure you didn't put a load of sludge into the pan that can clog the pickup screen, you really need to pull the pan.
Old Oct 19, 2018 | 03:04 PM
Light Doug's Avatar
Light Doug
Thanks! I drove it 50 miles home and it seems ok. What would it do run hotter?
Old Oct 19, 2018 | 03:54 PM
charliemccraney's Avatar
charliemccraney
At the worst, loose sludge and debris could clog the oil pickup screen, causing oil pressure to drop. At the best, the filter becomes full of debris more quickly and is bypassed - the oil is unfiltered at that point but you shouldn't loose pressure.
If you took care not to drop stuff down the pushrod holes or drain holes, it should be fine. You would really have to try to knock a lot of stuff into the crankcase by cleaning the heads.
Why is the entire engine wet in the first picture?
Old Oct 19, 2018 | 04:09 PM
Light Doug's Avatar
Light Doug
Good question. I friend of mine did it for me. Maybe degrease and pressure wash? It was a mess.
