2005 Excursion 6.0 question
Old Oct 17, 2018 | 09:25 PM
archerace7's Avatar
archerace7
In July my 2005 Excursion 6.0 diesel would not start hot one day, it has been running rough off and on for a while, I thought it was bad fuel, as it would come and go. But only once warmed up, ran great cold.
It cooled off, started, I took it home and parked it, driving a 2004 Excursion, with fewer miles, runs great.
After reading on the forums, I purchased a autoenginuity ford package, finally tried it out today, decided to try to figure out what is wrong, everything I read indicated a oil pressure to injector problem.
The Voltage Control Module section in the scanner, only registered 13 volts, while running, it would sometimes jump to 25 or 30, then drop back to 12 or 13. Is this Voltage Control Module the same as the FICM I am reading about, which is supposed to be around 48 volts.
I know it is a dumb question, but assume I know nothing about this, and you will be right..lol. The truck has brand new batteries, and they whirl the engine, so I assume they are fine, it has a brand new alternator as well.
If this is the reading for the FICM, then that is the place to start for sure, replacing it first.
Thank you one and all for any help with this.
Old Oct 23, 2018 | 12:40 AM
04badford's Avatar
04badford
In the power Stroke 6.0 world , we call it a Ficm , fuel Injection Control Module , there’s two sides ,
main power , which needs to stay at 48.5. / 49 v, nothing lower than ford base value of 45v
logic power , 12.0 to 13.5
vehicle power , 12.0 to 14.0
there will be some fluctuations in the readings especially when the glo plugs are on and driving , but not below say 10v and 45v anytime.you will see better numbers when the engine is heated up making the Ficm look better, it’s best to test Ficm Cold Koeo key on Engine off for the Test. You might be seeing the voltage on the Ficm relay but
Ed down at Ficmrepair.com will fix you up .
Rusty Wilder
Jul 27, 2019 05:57 PM
Abooton69
Jun 14, 2018 12:02 PM
jkittle
Jan 8, 2017 04:22 PM
2-6.0's
Apr 6, 2014 09:51 AM
hutch05
Dec 6, 2011 12:11 PM
