1984 F150 needs help. 351w with 2150 carb. Need help getting fuel parts. This truck was given to me so I figured I would try and get it running. Popped the hood to find no carb. What I know is missing at this time is pump to carb fuel line, carb mounting studs, Just bought a brand new 2150. Going to replace the tank and fuel pump and line. I can't seem to find the right fuel lines from pump to carb or find that exact studs to match. Any ideas?
Get an electric pump and 5/6 PSI fuel pressure regulator.Mechanical pumps fail with the use of ethanol fuels. no return line needed. plug it at the tank, get an Eledelbrock intake and a holey carb.
