Tool ideas....
Old Oct 15, 2018 | 03:20 PM
BillyBob69's Avatar
BillyBob69
Tool ideas....
So I have been looking at some time on getting a pressure bleeder system to flush n fill the brake system on my truck, the toys, the wife"s car etc.
It has been awhile due to the cost of them that I keep finding. I am looking for something that i can hook up to my air compressor and just go hit each wheel until it is all clean with new fluid.
So... DYI tool time.
Anyone got ideas, links or maybe something that doesn't cost $350+ ?
Would like it to push the fluid through so I just have to go to each corner and open the bleed valve until the fluid is clear.
Thoughts?
Thanks all!
Old Oct 15, 2018 | 04:03 PM
pirate4x4_camo's Avatar
pirate4x4_camo
I have a few diffrent pro level systems but honestly the HF one works as well as any of them on a standard setup like the F250, it’s my go to unless I have a unique problem to overcome.
https://www.harborfreight.com/automo...der-92924.html
Old Oct 15, 2018 | 04:59 PM
Colorado350's Avatar
Colorado350
I’d be watching CL, someone bought one thinking that same thing then realized they don’t use it. If you us IOS (Apple) go to the App Store and download CSMART for CL. You can actually set searches up, price ranges and locations then be notified immediately when an item posts. You may find a professional model for cheap!
Old Oct 15, 2018 | 08:38 PM
FordTruckNoob's Avatar
FordTruckNoob
Make your own with a garden sprayer.
Old Oct 15, 2018 | 10:45 PM
DieselDenny's Avatar
DieselDenny
Why the ruckus, just gravity bleed and put a hose in a brake jar. Science is everything.
Old Oct 15, 2018 | 11:43 PM
PrescottIce's Avatar
PrescottIce
I just put an air chuck through an old brake fluid reservoir cap, set my regulator to 4 psi, and made sure I didn't run out of fluid. It cost me nothing, I had the air chuck and I had an accurate low pressure regulator.
Old Oct 16, 2018 | 01:35 AM
Mike321's Avatar
Mike321
I would love to replace using channel-locks for a proper tool for the hose fittings for the water cooled lines. If there is a better tool, please let me know.
Old Oct 16, 2018 | 04:50 AM
FordTruckNoob
This:
https://www.toolpan.com/Lisle-17100-...hoCOmYQAvD_BwE
Or this for the harder to reach clamps:
https://www.toolpan.com/OTC-Tools-45...hoC-TYQAvD_BwE
Old Oct 16, 2018 | 07:23 AM
BillyBob69's Avatar
BillyBob69
OK that looks easy enough but.....
How do you monitor how much fluid is left in the canister? Or do you just keep checking?
I would assume 5 PSI is enough to do the job.
And last..what is the extra gauge and cap for? Or is that for a different vehicle?
Old Oct 16, 2018 | 03:24 PM
FordTruckNoob
Put brake fluid in the sprayer. That keeps the reservoir full of brake fluid as you bleed. You can put a whole quart in there and really flush the heck out of the brake system.
Yeah that gauge on the cap was a mistake I made with my first iteration . I put the gauge on the sprayer later. That gauge on the cap makes it a real bitch to screw onto the reservoir. I really should remove the extra guage but have been too lazy. Also, it's a cap for an Audi I don't own any more so there is not much motivation.
Old Oct 16, 2018 | 09:23 PM
Mike321's Avatar
Mike321
I'm glad I posted, thank you!
Old Oct 18, 2018 | 09:33 AM
'88 E-350's Avatar
'88 E-350
One man brake bleeder: gravity.
I use a hose clamp tool with a cable similar to the one linked, love it!
rattleNsmoke
Jan 14, 2015 09:03 PM
tps93ranger
1983 - 2012 Ranger & B-Series
Feb 11, 2013 11:24 PM
rkloehn
Modular V10 (6.8l)
Nov 11, 2011 07:44 PM
Se77vN
Oct 11, 2009 06:50 PM
Popa Tim
16
Nov 8, 2004 02:16 PM
