So, in just having purchased my first diesel truck (2000 F250 7.3L) I was going to go ahead and chang the oil in my truck. Now, I live in Indiana and Its going to be winter here very soon, I figured I might go with Mobil 1 5w40 diesel oil and a mastercraft filter. I figured that the synthetic might be better for the early morning 0 degree days. If anyone has any comments, I would much appreciate it. I run Mobil 1 in my porsche and cadillac but that is what the factory recommends. Have heard nothing but good reviews about Mobil 1 though.
Please comment and let me know if this is a good choice or not.
5W-40 will be great. It's common enough to run it year round in the 7.3 and 6.0, both of which were originally specified for 15W-40. Really calms down cold starts
Minutae/personal opinion time. I recall that Mobil1 TDT carries a dual CK-4/SN rating, which means the oil has a lower 800 ppm phosphorous content for newer model emissions and is gas-engine compatible. I use Rotella T6 which does not carry the dual rating and can have a higher 1000ppm content.
Do NOT use an FA-4 rated oil - they are not backwards compatible to older years. Using Delo as an example, it will have a yellow label (versus the CK-4/SN having a red label).
Fuel-wise, Opti-Lube sells a winterizer that is mostly just an anti-gel and demulsifier. Some Midwest states (coughIllinoiscough) have higher biodesel requirements than other places, and bio is more susceptible to both clouding/gelling, and having a higher water content. If you have to run anything over B5 in the winter, I would use an additive regardless of what the state treatment laws are. In 11 years I've had one fuel problem - it was in Chicago, with diesel bought in Northern Illinois, treated with a double dose of Power Service's winter additive, and it still completely waxed up the primary fuel filter. You can make up your own mind about other types of fuel additives, but Bio + Cold for me means I will always use a supplemental anti-gel additive. best diesel fuel additive
Thank you for your input. Will have to look into what the diesel grade is that I am currently filling up with. I have been purchasing Diesel from the Speedway gas station by the interstate.
Welcome FTE. In the future I recommend you post in the 99-03 7.3L Forum. There’s a lot of good oils out there. I found Triax oil and have been running it for over a year. My truck runs smoother, starts better and is actually quieter with the Triax than it ever did with the Rotella. Here’s a thread: https://www.ford-trucks.com/forums/1...il-review.html
I'm also a fan of Rotella T6. It's an excellent oil and can be had at a great price. If you have Menards nearby, they currently have it on sale for $19.99 a gallon, plus you get 11% back in store credit.
https://www.menards.com/main/tools-h...6027658&ipos=1
You have to use a synthetic media filter with synthetic oil. Mobil 1. M1-210, Wix 51372XP. Wix makes NAPAs filters ask for the equivalent wix number. Only other one Id consider is a Baldwin. I dont have that synthetic filters cross ref #.
