Weird brake function
Old Oct 14, 2018 | 09:01 AM
Shawner1974's Avatar
Shawner1974
Good morning all! I have a strange problem with my brakes. When it is warm out, they work great. When it gets down to 40 degrees, the pedal is very stiff until the truck warms up. I thought maybe it was condensation freezing but it's not that cold yet. Vacuum seems to be ok, although I haven't checked it with a gauge. I do have a new master cylinder/booster I have not installed yet, but I'm not sure that will solve the problem. Any ideas?
Old Oct 14, 2018 | 02:03 PM
CharlieXLT's Avatar
CharlieXLT
Vacuum booster. When it's cold, parts have contracted enough to cause a leak at a bad spot. As the engine bay warms up, parts expand and the leak starts to seal up. Years ago, a friend had a 73 Duster with power brakes that did the same thing in the winter. He was always a broke-*** college student with no money and couldn't afford a new booster so it stayed that way for a long time. Finally got one for free from a friend that wrecked and totaled a 73 Valiant. Brakes on the Duster worked perfectly after that.
Kinda the same thing happens with cold solder joints on a printed circuit board. As a piece of electronic equipment heats up or cools down, the poor solder joint either makes a better or worse connection due to expansion/contraction.
I'm sure once you get that new booster in, that problem will go away. Don't forget to replace any vacuum hoses that you think might be questionable looking. Good luck!
beermonger
1978 - 1996 Big Bronco
Oct 24, 2010 09:24 PM
richardbink
Apr 9, 2010 03:39 PM
csangster
Sep 30, 2008 10:00 AM
Defcon888
Dec 14, 2006 09:13 PM
Clearcutter
Feb 9, 2003 02:41 PM
