1986 emissions nightmare
Now for the whopper. I've tried running the codes with my reader and have been unable to get them. I've cleaned the connections on the red multi-pronged connection and the single connection on the red/white wire. I, of course, have the key on, and even put the manual transmission in neutral while holding the clutch in (after powering up the reader and pressing test/hold). I even took apart the computer and saw no breaks on the back of the board. What I have not done, however, is start the truck, let it run for 10 minutes, turn the ignition off, turn the key back on and run the "engine off key on" procedure; I'm wanting to get it running decent before torching the brand new cat with a super rich mixture. Is it possible to get codes without warming the truck up?
I'm wanting to keep the stock emission system as all components are present and appear to be in good shape... but a fried computer may end up being the straw that results in my bully getting durasparked.
Thank you in advance for your help with this... Ray
So, I bolted on a 4 foot pipe to the manifold and left the catalytic convertor off and the air pump line disconnected (neighbors aren't too happy with me). I did find a Walker kit to properly connect said smog/air pump. However, I'm stumped on getting codes still.
I did warm the truck up and felt the outlet of the air pump and there was zero pressure and/or airflow. I tried following the procedure for the code reader to a T; hooked up reader (as seen in picture), made sure reader off, started truck, warmed it up, turned ignition completely off, waited 10 seconds and turned ignition on to observe "emissions light" cycle on/off, turned reader on and pressed test/hold, got back in truck and held clutch in with tranny in neutral... no codes and nothing in the memory.
(1) Is it safe to assume the smog pump is not properly working as it is not blowing out the outlet?
(2) Is it safe to assume computer is not working as no codes are being read?
Thanks again for helping folks
EEC IV Self Test hookup
If you look at the connection diagrams in the above link, you will see the indication device, whether it is a testlight or old voltmeter, uses the battery + for power, and the computer grounds terminal #4 to give the code indication. How does your little code reader get power? It needs to get power from somewhere to get an code indication. If it gets power from the plug somewhere, maybe yours is missing power. I see that it has numbers on the screen, does it take a internal battery in the reader?
Why don't you try the method in the above link and see what you get?
Dave ----
Thanks again all for your help, I've given it a valiant effort to keep this stock but think I might have to make er simple and easy to work on.
Disconnected wire above valve cover and next to carb
Blocked vacuum line running to \"tree"
If you want to do this in small steps, it will run ok with the retro fit distributor system and the feedback carb, till you can get an older carb for it.
do you have a multimeter? No codes ok...next is to verify that the computer is getting power. Fuse could simply be blown.
Also, there is a separate relay for the computer, check this.
Where are are you located? Maybe someone could help you.
I live in Medford, Oregon and was thinking of maybe running my truck out to a mechanic to help as I'm on the edge of wanting to Duraspark it. This could be a problem, though, as the other time I converted an 86 Bronco to Duraspark the wiring was fairly stock; I simply spliced in the 2 factory ignition wires to the 79 harness I bought at a junkyard, spliced in a one ohm resistor and connected the "run" wire to the positive side of the coil... I ran that Bronco for years that way. However, my current project has some "special" additions including non-stock wires leading to/from a removable security chip that when removed in the cab renders the truck inoperable (the starter relay is far from stock with spliced in wires).
I feel compelled to keep at this project by purchasing Painless Wiring part #30812 and starting over but am hesitant to cut/splice the red/white wires coming from the ignition control module. I have been unable to find a junkyard that has a Duraspark harness for sale.
Since rebuilding the carb, the truck does seem to run better and I suppose I might drive it for a while and think things over...
Thank you all again. Seems every time I find another bullnose, I battle with the previous owner's modifications
Also sometimes these code readers don't work for whatever reason, have you tried the simple test light method to read codes? See bottom illustration for reading codes with a $4 light. Also, If you choose to go to a shop, make sure they know old fords before you waste money.
Either way, I'd troubleshoot with the VOM and test light as noted first.
Im willing to bet the solution will cost very little, just a loose wire or something.
