1948 Ford Truck Horn
Old 10-14-2018, 09:38 PM
pezsox's Avatar
pezsox
pezsox is offline
I feel like my horn does not compress enough. Does the button push down in a “springy” or does the button just “rock” to the sides?
Old 10-14-2018, 09:43 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
They don't press down very much. I think mine only moves about an 1/8". They are not as springy as the earlier trucks and cars with the big coil spring under the horn button.
Mark
Old 10-14-2018, 10:09 PM
pezsox's Avatar
pezsox
pezsox is offline
My issue is that if I set it up like the bottom pic, is the wire can slip thru the middle of the prongs. Is that what it is supposed to do?
Old 10-15-2018, 01:45 PM
49fordv8f4's Avatar
49fordv8f4
Here is a photo of how it goes together.
The dome goes down and the tabs set on the shoulder of the wire connector. When you press the horn button, the outside edge of the ring will touch the copper plated cover underneath and complete the connection from the horn wire to ground.
Mark
Old 10-15-2018, 11:44 PM
pezsox's Avatar
pezsox
pezsox is offline
A few more questions. Is the spring installed like pic 1 or 2 (confusing myself with asking about done) also in the last pic, my wire end washer slides alsmost freely they the spring, certainly not like the pic shown. Any ideas? This is so simple, but still confused! Lol
Old 10-16-2018, 09:57 AM
49fordv8f4's Avatar
49fordv8f4
The spring is installed like pic #1, but the tips of the spring should set on top of the flange of the wire connector and hold it down against the insulator. Is your spring a repop? It looks like the distance between the tips of the fingers is too wide to set on top of the wire connector flange. The flange on the wire connector may be too small also. In my photo you can see the spring tips setting on the connector flange. My spring is original and so is the wire connector.
Mark
Old 10-16-2018, 10:14 AM
pezsox's Avatar
pezsox
pezsox is offline
it is a new wire from....LMC so that should be enough information as to why it isn't correct. I can pull that wire and metal end thru the disk without touching. I have tried to bend the prongs in to touch, but that flattens the disk. Can a brass washer be used under the wire end do you think?
Old 10-16-2018, 04:05 PM
49fordv8f4's Avatar
49fordv8f4
You could solder a brass washer to the connector under the flange. Just slipping a brass washer on the connector under the flange wouldn't hold the wire down, but it may still work just fine.
Mark
FordRun
18
09-19-2012 08:33 PM
fisheasy
10-05-2010 07:08 AM
oneofakind97
11-09-2007 07:12 PM
51PanelMan
04-03-2005 03:43 PM
Earl
09-28-2003 08:15 AM
Quick Reply: 1948 Ford Truck Horn
