1978 - 1996 Big Bronco
1978 ford bronco saginaw swap
Old 10-10-2018, 04:24 PM
Jwells1993's Avatar
Jwells1993
Jwells1993 is offline
hey guys i got a 78 ford bronco with a 460 and c-6 someone before me put in motor and a Saginaw power steering pump they took two high pressure hoses and made one with a compression fitting well after years and years of running it the pressure fittings arent holding it anymore and the line leaks anyone know what hose i should buy preferably not one i have to cut and splice thanks
Old 10-10-2018, 08:34 PM
1985 Bronco's Avatar
1985 Bronco
1985 Bronco is offline
I would try one made for a 80's 460 powered van. Vans usually had the Saginaw pump. I don't know if vans were available with 460s in the 70's. You should bring your hose to the parts store and compare the fittings before buying. Or you could go to a truck stop and have them make you a new one from scratch.
Old 10-11-2018, 11:35 AM
BigBlue 94's Avatar
BigBlue 94
BigBlue 94 is offline
Find out what year of brackets hold the sag pump on and get lines from the closest year of 460 van to that.
or I can reference some numbers for my 85 swap when i get home. Mone is in the works with AN lines, but the port thread sizes should be the same.
iirc the pump outlet is an m16x1.5 special o-ring.
Jwells1993
10-10-2018 05:07 PM
randre
10-01-2018 07:34 PM
460 FORD MAN
02-04-2017 08:15 PM
2Wise4aGM
12-19-2002 11:10 AM
buckford
01-05-2002 12:44 AM
Quick Reply: 1978 ford bronco saginaw swap
