1978 ford bronco saginaw swap - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Old 10-10-2018, 04:24 PM
Jwells1993
Jwells1993 is offline
Jwells1993 is starting off with a positive reputation.
hey guys i got a 78 ford bronco with a 460 and c-6 someone before me put in motor and a Saginaw power steering pump they took two high pressure hoses and made one with a compression fitting well after years and years of running it the pressure fittings arent holding it anymore and the line leaks anyone know what hose i should buy preferably not one i have to cut and splice thanks
Old 10-10-2018, 08:34 PM
1985 Bronco's Avatar
1985 Bronco
1985 Bronco is offline
1985 Bronco is starting off with a positive reputation.
I would try one made for a 80's 460 powered van. Vans usually had the Saginaw pump. I don't know if vans were available with 460s in the 70's. You should bring your hose to the parts store and compare the fittings before buying. Or you could go to a truck stop and have them make you a new one from scratch.
Old 10-11-2018, 11:35 AM
BigBlue 94's Avatar
BigBlue 94
BigBlue 94 is offline
BigBlue 94 is gaining momentum as a positive member of FTE.
Find out what year of brackets hold the sag pump on and get lines from the closest year of 460 van to that.
or I can reference some numbers for my 85 swap when i get home. Mone is in the works with AN lines, but the port thread sizes should be the same.
iirc the pump outlet is an m16x1.5 special o-ring.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
