Horsepower? Torque?
Old Oct 10, 2018 | 10:44 AM
Baker66FordF100's Avatar
Baker66FordF100
4wd High
Horsepower? Torque?
I have a 78 308w (it is .40 overbored) with a HEI distributor, stock heads but the exhaust sides are ported, an aluminum intake manifold, and a 4 barrel carburetor. behind it is a C6 and a Ford 9 inch with 3.70 gears. What do you think it will make in horsepower and torque?
By the way it has a 63 grille
Old Oct 10, 2018 | 10:46 AM
Baker66FordF100
4wd High
Picture Info
The picture was taken as we were taking the engine out for the first time.
Old Oct 10, 2018 | 10:52 AM
ford390gashog's Avatar
ford390gashog
Maybe 250hp 310 TQ and that's conservative.
Old Oct 10, 2018 | 10:58 AM
Baker66FordF100
4wd High
That's pretty good for an engine that has been sitting in a field for about 20 years.
Old Oct 10, 2018 | 11:01 AM
Baker66FordF100
4wd High
Thank you, you are pretty cool
Old Oct 10, 2018 | 11:57 AM
James_Western_Canada's Avatar
Sorry, but a 302 2bbl with a stock hydraulic cam, even with the addition of an intake, 4 bbl & headers, IMO will not come close to 250.
Think about the '83/84 Mustang, when they first put a 4bbl carb on them, (and almost certainly more cam than earlier 2bbl engines), and they were something in the order of 175 HP........
If the OP neglected to mention the addition of a more aggressive cam, then the numbers would get better, but even the '85 5.0L with hydraulic roller cam was only rated @ ~225HP.............
Old Oct 10, 2018 | 12:47 PM
Crop Duster's Avatar
Crop Duster
The only book I have handy stops at 1975 but they didn't get any better by 1978. The most powerful 302 in 75 was in a t-bird and it had a whopping 129 hp. Any gains you got with the 4 barrel and a little porting will be lost to the internal friction in that C6. Those little engines can make impressive HP an torque but you have to throw a lot of parts at one to get it there.
Old Oct 18, 2018 | 10:35 AM
cosmofennema's Avatar
cosmofennema
There were good reasons Ford never put the 289 in trucks.
No torque.
Horsepower is a calculation: torque times RPM divided by 5252. Therefore, the faster an engine turns, the more horsepower it can (theoretically) make.
289-302's are rev happy torque-less small car motors. Reason: no stroke, which means no leverage for the exploding mixture to exert upon the crankshaft.
302 = 3" stroke - 290 ft/lbs
352 = 3.5" stroke - 350 ft/lbs
390 = 3.78" stroke - 390 to 427 ft/lbs
All of the above utilise 4" bore (390 4.05", pretty dang close)
Trust me, you WILL feel 50 ft/lbs of torque increase.
BTW, all the above is based on '69 specs (65 for 352) and my own experience.
Cosmo
Old Oct 18, 2018 | 11:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The first year that Thunderbirds were available w/a 302 was 1977. 1972/76 Thunderbirds came with the 460.
Old Oct 18, 2018 | 12:29 PM
Crop Duster
You're right ND. I saw that they just listed all the Ford engines together after I typed that. But even the once mighty 460 had been detuned to 218 HP.
Old Oct 19, 2018 | 09:32 AM
fuelsmoke1's Avatar
fuelsmoke1
I bought a 95 Mustang engine for my 65 f100 after my 240 went south. The engine I bought is a 5.0L HO. Supposed to be 225 HP with the EFI on it.
chucks blazer
Nov 20, 2004 01:12 PM
iskybantilus
May 19, 2004 02:43 PM
90ebbronc
Jan 6, 2004 06:52 AM
ckrichard
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 7, 2003 09:50 AM
