Help with flywheel reinstallation
Old Oct 10, 2018 | 09:29 AM
95fiveoh's Avatar
95fiveoh
I'm reinstalling my machined flywheel on my 1995 302. I have a couple questions that I need help with.
1. I've read the torque spec for the bolts is 75-85 ft lbs. My torque wrench only goes up to 75 ft lbs. Is 75 enough?
2. I've read you need to coat the bolt with thread sealer or oil will leak out. Is this correct?
3. What is the tightening sequence for the flywheel bolts?
Thank you!
Old Oct 10, 2018 | 09:40 AM
Freightrain's Avatar
Freightrain
75 ft/lb is fine.
Yes, use some kind of thread sealer. The crank bolt holes are through holes on a 302 and if you don't seal them it will seep oil and ruin the clutch in short order.
I cross tighten just like a wheel.
Old Oct 10, 2018 | 10:24 AM
95fiveoh's Avatar
95fiveoh
Thank you, much appreciated!
Old Oct 10, 2018 | 10:30 AM
ford390gashog's Avatar
ford390gashog
Clean the crank bolt holes out, use a thread sealer that does not alter torque such as loctite yellow. You can accidentally over torque if you use a oil based thread sealer.
Old Oct 10, 2018 | 04:14 PM
95fiveoh's Avatar
95fiveoh
Will do. The clutch kit just came in the mail today from RockAuto. It's looking like rain tomorrow so I may not get to putting it together until Friday or Saturday, but I'll have everything ready to go and know what to do.
skid2964
Aug 1, 2023 06:56 PM
jmm
May 25, 2011 10:57 AM
topgunn
Aug 15, 2007 01:38 AM
5.0 ford
1983 - 2012 Ranger & B-Series
Oct 19, 2006 12:42 PM
