Now What?
Old Oct 9, 2018 | 08:11 PM
roostercrows's Avatar
roostercrows
Now What?
Me again...
So my truck was running great after all the weekend work that I had done (see here if you haven't been following https://www.ford-trucks.com/forums/1...n-my-legs.html ).
On my way home from work the truck went into like a tractor mode, running really rough and had no power. I managed to limp it home but it felt like it could stall at any point, I was barely able to pull into my driveway.
I left it running and had a look under the hood to see if there was anything noticeable, there wasn't. While it sat there it got better for a few seconds, then worse for a few seconds, then better, then worse, then better and it stayed better. No CEL but I thought I'd check for codes anyway on my Edge Insight. Code 1316 was there and from reading on here I found it to be the IDM. But just what with the IDM?
I would say that it is highly likely that since I was under the valve covers yesterday that the issue is probably related to that. Probably one of the harnesses not fully/properly connected, am I right on this line of thinking? If so, how do I know which side to go after? If not where do I start to diagnose this more fully?
I started it again tonight and it ran better but it felt like it was ready to go back to the tractor mode at any time. Would it be safe to drive to work like this (about 10 miles) or should I look for a ride for tomorrow?
I think I know the answer to that already but I hate bumming a ride so its worth asking.
Old Oct 9, 2018 | 08:44 PM
Colorado350's Avatar
Colorado350
James, I would agree with your harness guess…at least start there. I would also consider removing the chip until you figure it out, just to eliminate it from the equation. Good luck
Old Oct 9, 2018 | 08:59 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Almost certainly the harness since the timing correlates to your recently working in the area.
Using Forscan run a cylinder contribution test will likely revel which bank is the culprit.
Old Oct 9, 2018 | 09:00 PM
timmyboy76's Avatar
timmyboy76
Edge has a tractor mode..
take edge off and see what happens
Old Oct 9, 2018 | 09:38 PM
Stewart_H's Avatar
Stewart_H
If you can still get it to start, just run it for a minute, shut it off, and see which side is cold versus which side is warmer from the combustion.
Stewart
Old Oct 9, 2018 | 09:50 PM
schlepprock250's Avatar
schlepprock250
Before you tear the valve covers back apart check the plugs where the wiring harness connects to the valve covers. Look close to see if either one appears to be loose. If so you still may want to go back in to be sure they're tight and do a shim. Shaved down quarter will work.
Haven't read your other post so if you replaced the harnesses no need to shim them.
Old Oct 10, 2018 | 08:41 PM
roostercrows
Hey guys, thanks for the replies.
This point its gonna have to wait until Friday when I'm off. I'm pretty sure I've narrowed it down to the passenger side harness. Thank you for the tips on how to diagnose the side. I must have not put it together tight enough?
Schlepp, I did do the harnesses, as I understand it they do not need to be shimmed because of design improvements.
Old Oct 10, 2018 | 08:53 PM
Colorado350
Stewart
WTH? Start it and see which side is warm? What kind of common sense approach is that?
Old Oct 16, 2018 | 09:39 AM
roostercrows
Hey All,
So I tried to do what Stewart recommended in that I would start the truck let it run for a minute and then check for what side is cold but every time I started the truck, it ran fine!! lol I knew I had an issue though so I took what I thought was an educated guess and attacked the passenger side. It turned out to be the wrong one... lol I left to go to a buddies house to install my new exhaust and it ran rough again.
Anyway, long story short I did the drivers side and so far so good. It looks to have been an issue with the connection under the valve cover although I couldn't see anything wrong with it. I took it apart and reconnected and squeezed it really tight and it has been running normally since.
Old Oct 16, 2018 | 11:03 AM
PrescottIce's Avatar
PrescottIce
Here's to crossed fingers.
Old Oct 16, 2018 | 01:40 PM
brian42's Avatar
brian42
Veteran: Navy
Correct. As schlepprock250 mentioned, the new OEM design holds the connection so no 50 cent mod required.
Old Oct 17, 2018 | 12:42 PM
roostercrows
Its doing it again.
I can only assume that the plug under the valve cover slowly pulls apart with vibration.
I think I'm going to wrap a wire around the plugs and cinch it shut tighter and more permanently.
or would the 50 cent mod be a better idea?
Suggestions?
Old Oct 17, 2018 | 01:39 PM
timmyboy76's Avatar
timmyboy76
Take the vc's off and fire it up. Start messing with connections and in hope you find the problem. In meantime, remove any chip tuner..etc
Old Oct 17, 2018 | 02:11 PM
brian42's Avatar
brian42
Veteran: Navy
I never had an issue with the original UVCH or VC gasket and I went new OEM for both when I did my injectors earlier this year.
FWIW I have read plenty on the 50 cent mod over the years. I have never read of a "I-think-I'm-going-to-wrap-a-wire-around-the-plugs-and-cinch-it-shut-tighter-and-more-permanently" mod.
Just my 2¢
Old Oct 17, 2018 | 04:00 PM
roostercrows
All I'll say to that Brian is that things are obviously progressing....lol
I know it sounds bad.
