Sponsored by: Real Truck
2005 6.0
Old Oct 9, 2018 | 03:49 AM
zed326's Avatar
zed326
So I have a 2005 6.0 Super Duty. Whenever I hook up my travel trailer and pull it the little wrench light comes on. When I scan the codes I am getting the code for the oil correlation temperature. From looking it up it is saying it is the high pressure oil pump. I have had this done at Ford and this happening again does anybody know a good aftermarket high pressure oil pump or a way to fix this problem?
Old Oct 9, 2018 | 07:54 AM
xcrsp440's Avatar
xcrsp440
What is the code?
Old Oct 9, 2018 | 10:17 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Since you said "oil correlation temperature" it's likely the wrench light is the result of a P012F code. It's the oil COOLER that needs to be replaced, not the high pressure oil pump.
Old Oct 9, 2018 | 01:03 PM
m-chan68's Avatar
m-chan68
THIS is likely the correct answer. I can't fathom how any Ford dealership technician would misinterpret that code to have anything to do with the high pressure oil pump being the cause.
Old Oct 9, 2018 | 03:46 PM
zed326's Avatar
zed326
I will check when I get home on the proper code number but I believe that is what it is. Is that something I can do in the driveway? I can do anything short of taking the motor out
longbeau
May 26, 2018 10:50 AM
rowdyredneck
Jul 19, 2016 01:00 PM
tjustice
Feb 8, 2013 01:31 AM
ford7.3l
13
Jul 27, 2012 04:16 PM
hi-jacker
Oct 27, 2006 05:01 AM
