MC Cap/ Gasket
Old Oct 8, 2018 | 04:33 AM
Matt1966's Avatar
Matt1966
MC Cap/ Gasket
I am probably stupid asking a question when I already got the answer but sometimes I just have to know WHY!!
I got my new Gasket for the MC Cap today. I have always thought the side with the "rubber walls" should point
down against the surface of the Brake Fluid. This to protect the Fluid from sloshing around in the MC then driving/breaking.
Now , when reading on the old Gasket I understand the "walls should point up against the Cup. I dont understand the purpose
of this "rubber walls"???
Old Oct 9, 2018 | 06:44 AM
Ozzie H.'s Avatar
Ozzie H.
Sometime it's difficult to understand the philosophy behind a particular design. Perhaps it is to allow the gasket to descend into the reservoir as the level of the fluid lowers. It is likely that a bit of movement of the fluid in the reservoir is not considered detrimental. It would nice to be able to hear from someone who has insight into the design.
Old Oct 9, 2018 | 08:40 AM
HoustonDave's Avatar
HoustonDave
I was always told it was to keep air volume consistent above the fluid and serve as a visible indicator that you were using fluid. The first so that gradual fluid loss would not create a vacuum in a tightly sealed reservoir, the latter to visually indicate by the center 'ballooning' toward the fluid that you were using fluid somewhere and it was time to investigate and top off.
redpepsi31
Mar 4, 2017 02:39 AM
Corallis
Apr 30, 2015 02:40 PM
Myfreeford
Aug 10, 2014 02:08 PM
2001F1Fitty
1997 - 2003 F150
Jul 18, 2006 10:16 AM
NDrum2005
Oct 29, 2005 03:44 PM
