Driver Side Rear Seat Release
Old Oct 6, 2018 | 10:51 PM
07 F250 Aggie Mobile's Avatar
2019 F350 Crew Cab DRW, anyone know how to get the driver side REAR seat to fold down? There isn't a visible release lever/strap that I can see.
Old Oct 6, 2018 | 11:10 PM
blueiron's Avatar
blueiron
There should be a paddle latch on the bottom of the rear seat to release the seat and fold it down.
Old Oct 6, 2018 | 11:19 PM
villestrip's Avatar
villestrip
This video shows you how. Its for a F150 but its the same on my 2017 F350. Kind of a pain.
https://www.youtube.com/watch?v=mPsC...ature=youtu.be
Old Oct 6, 2018 | 11:37 PM
gravedgr's Avatar
gravedgr
You're talking about the seat back? If its like the F150, there is pin/latch that you can reach with your hand (easier when the seat bottom is partially up, lifting the back up and away from the rear of the cab). Pull it up and the rear unlatches and folds down. There is a company that makes a strap that attaches and makes it easier, but I never had an issue on my F150 once I figured it out.
Old Oct 7, 2018 | 01:05 AM
Tx.Hoon's Avatar
Tx.Hoon
The 2019 has a strap on the side of the seat that you have to pull. It is close to where the seat bottom meets the seat back.
Old Oct 7, 2018 | 06:27 AM
StormRyder's Avatar
StormRyder
$33.00 https://www.builtrightind.com/products/
Can't say with B&O but Sony used up most of the space on the '18.
Rich
Old Oct 7, 2018 | 07:26 AM
Poncho450's Avatar
Poncho450
Mine didn't want to latch again once I found it and released it. Not a big deal, there's really not much for usable space back there in my case.
Old Oct 7, 2018 | 07:28 AM
NorEasterMA's Avatar
NorEasterMA
I built my own release for it. Non-Sony stereo here so plenty of useable space. Gotta reach down with a combination wrench to pull up on the pin the first time. Name:  photo477.jpg
Old Oct 7, 2018 | 10:03 AM
Tom N OH's Avatar
Tom N OH
I drilled a hole in the pin on mine & threaded the keyring from my FTE lanyard that I got from here through it. Just leave the end of the lanyard draped over the seatback.
Old Oct 7, 2018 | 10:04 AM
esa's Avatar
esa
Originally Posted by StormRyder
Thanks for the link!! Went to buy the adapter, had to buy their clever bedside rack system too.
Old Nov 4, 2018 | 09:14 PM
JackalAR's Avatar
JackalAR
I don't seem to have a factory strap on my release lever in my 2017. Is there a trick to releasing it without having one to begin with?
Old Nov 4, 2018 | 09:57 PM
xxxsherpa's Avatar
xxxsherpa
No strap on the '17. Lift the bottom seat about 3" before pulling back seat forward (to gain a little more access). Feel behind seat for a small metal pencil size pin and lift up.
Old Nov 4, 2018 | 10:04 PM
ExtremeDuty's Avatar
ExtremeDuty
Took my brand new F350 to the dealer to get the seatback to latch. Had to lift the bottom of the seat slightly to make it work. I already put the Built Right setup on it. Service guy told me the seat back is not meant for the consumer to operate, only service personnel to access electronics back there. Yeah, whatever. Just happens, my 5th Wheel hitch kit fits perfectly back there.
Old Nov 5, 2018 | 12:39 AM
hobbie1's Avatar
hobbie1
Bought the Builtright for mine - works great - was a bit expensive but its all relative the truck had a sticker of almost $72K
Old Nov 5, 2018 | 04:27 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
My '18 has a short nylon strap on the release pin. To get it to latch, I have to slam the seat back
