1978 - 1996 Big Bronco
No Electrical Power
Old Sep 25, 2003 | 05:40 AM
Luke Peterson's Avatar
Luke Peterson
No Electrical Power
Has anybody had this happen to them? I hit a bump on the road the other day and the bronco went dead. No power to anything except the alarm system. Will not turn over, no lights, no radio. I was thinking that it was the ground to the chasis or to the starter. Any ideas?
Thanks,
Luke
1984 Ford Bronco
Old Sep 25, 2003 | 10:16 AM
bdclark's Avatar
bdclark
I made a u-turn and my battery slid over and melted the end of the negative cable at the terminal. I would take those of and make sure there is no corrosion, and possibly replace your solenoid as well. i am not sure how a bump would affect it, but your symptons sound like a solenoid. Good Luck
Old Sep 25, 2003 | 02:28 PM
frogger01's Avatar
frogger01
I know if the oil pressure lead grounds out it will kill the engine but your problem sounds like the ground lead from the engine broke off or a fuseable link went *pop*.
Old Sep 25, 2003 | 09:57 PM
BOJOFASO's Avatar
BOJOFASO
i never heard of a grounded out oil pressure sender wire killing the engine , in all cases i believe the sending unit creates a ground when you have oil pressure. the older senders are of a variable ground type which lets the gage work. on a newer one the sender just grounds and the gage has a resistor across it so it does not pin the gage.
there are fusible links for chassis power connected to the batt side of your solenoid . to check them take an ohm meter and probe from one side of the link to the other and you should see a short if the links are good. there are more than one ground on your bronco , one very heavy gage wire connected to the block for the starter. then from the block to the fire wall and another off of the batery terminal to the radiator support area. does the vehicle cranck? the heavey ground wire is not a good chassis ground because the engine is isolated by rubber motor mounts. take some jumper cables and clamp one side to the negative batt terminal and clamp the other side to the body of the bronco and see if your electrical system comes back.
Old Sep 26, 2003 | 03:56 PM
jsscart's Avatar
jsscart
Sound like the Alt harness from the starter soleniod to the atl and bat. Just had to rebuild my harness I have the wiring diag in my gallery.
Old Sep 29, 2003 | 09:00 AM
Luke Peterson
Thanks for everyone who replied. It turned out to be the fusible link from the starter selenoid. $3.00 part.
Thanks,
Luke
