Sponsored by: Halo Lifts
Adding Apps from phone in a 2015 F150 XLT that has MyForTouch.
Old 10-05-2018, 08:37 AM
ArmamentDawg's Avatar
ArmamentDawg
ArmamentDawg is offline
How do I get Sync to see the apps on my Android phone? I have Sync with MyFordTouch and the touch screen. I cannot get the system to see the apps on my phone.
TIA
Old 10-06-2018, 08:06 AM
rmccbride's Avatar
rmccbride
rmccbride is offline
I’m not sure but I think you need to buy a newer truck or replace your sync 2 with a sync 3.
Old 10-06-2018, 08:18 AM
ArmamentDawg
Old 10-06-2018, 08:19 AM
GABAR's Avatar
GABAR
GABAR is offline
TIA
That`s one of the bad things about SYNC / MFT, it`s not capable of supporting newer technology and one of the reasons Ford went to SYNC 3 which came out on the F150`s starting with the 2016 model year. The best thing that you can do is upgrade your system to SYNC 3 but it`s not cheap to do.
Old 10-06-2018, 08:26 AM
GABAR's Avatar
GABAR
GABAR is offline
LOL......Don`t get mad because all is not lost.
When you have time, go on YouTube and look up 4D Tech. They have videos showing what`s required and needed for the conversion from SYNC 2 / MFT to SYNC 3 and it can be done by you in your driveway. They also have a website where you can purchase the parts but there are members on here who can sell you the same system for quite a bit less than 4D Tech.
I hope this info helps you out.
Old 10-06-2018, 11:38 AM
Wiggums's Avatar
Wiggums
Wiggums is offline
Ah, if you recall in the other post of yours, I said I would never consider a 2015, only the 2016's and above because it has Sync 3 which uses Android Auto or iPhone. Sorry if I wasn't clear on that one, but I love Android Auto on my 2016. The Waze works flawlessly and it appears on my big 8 inch touch screen.
Old 10-07-2018, 08:27 AM
ArmamentDawg
This is awesome. I will be getting the navigation module to add to my truck. Thanks!
Old 10-08-2018, 12:25 PM
GABAR's Avatar
GABAR
GABAR is offline
Also, don`t forget about the CarPlay USB hub.
Old 10-09-2018, 10:25 AM
CR172's Avatar
CR172
CR172 is offline
I have a '15 with the MFT as well. Wife has Stync3 in her Edge. Personally I wouldn't bother with upgrading. I can't stand her screen. I end up turning it off when I'm driving her car. Nothing but an 8" screen of distraction. I was taught how to read a map. I don't need no stinkin' navigation.
Old 10-09-2018, 04:12 PM
pikapp's Avatar
pikapp
pikapp is offline
Agree. After looking at YouTube-4D Tech video on the upgrade, I really didn't see an advantage or benefit. The MFT and Garmin work just fine.
Old 10-09-2018, 04:45 PM
Wiggums's Avatar
Wiggums
Wiggums is offline
I don't even need the optional navigation system on my Sync 3 when I can just plug in my phone and use Google Maps or even Waze. My friend's wife has the older Sync 2 in her Explorer, she definitely wasn't happy when she played with my Sync 3.
She was also amazed at how my phone worked well with my F-150.
Old 10-09-2018, 04:57 PM
CR172's Avatar
CR172
CR172 is offline
To upgrade to Stync3 w/nav is a $2000 upgrade thru the 4D website. Definitely not worth it. Especially when you hear and read about the problems with it.
Old 10-09-2018, 08:26 PM
miner999r's Avatar
miner999r
miner999r is offline
don't you just miss the days when the options were colour, auto / std. a/c or not, radio or not, if radio AM only or AM / FM, power brakes and steering. That was the big list there were no other choices unless you went high end models.
On trucks the wipers worked on the vacuum system which meant they only worked when you let off of the gas. Batteries were often 6 volt, the starter switch was a pedal on the floor and hi / lo was a button on the floor and trans. were manuals with maybe a split axle. Heaters and defrost was so / so and you had to stick frost shields on the inside of the windows or seeing out was a challenge. Best of all you could rebuild an engine in your drive way if necessary.
Old 10-09-2018, 08:31 PM
Wiggums's Avatar
Wiggums
Wiggums is offline
Uhmm, nope.
Old 10-09-2018, 08:48 PM
ArmamentDawg
I appreciate all the responses but I do not have Sync 3 in my truck. I do have Sync 3 in my 2016 Mustang GT Premium. I only have Sync w/MFT
Quick Reply: Adding Apps from phone in a 2015 F150 XLT that has MyForTouch.
