2011 F150 Supercrew cab
Old Oct 3, 2018 | 07:47 PM
milkman713's Avatar
milkman713
I purchased my 2011 F150 last year. Love this truck. It was an upgrade from the 97 Explorer I had for 11 years. The only problem I am having is the dash says the rear
​​door is open but it is not. So I ordered a new door latch and installed it. I still have the message on my dash. Any ideas to what could be causing this?
Old Oct 4, 2018 | 06:39 AM
calvynandhobbs's Avatar
calvynandhobbs
I'm assuming you misspelled crew cab in the title, but there are several threads on the crew cab rear door light being on and the problem is usually the wiring in the B-pillar gets pinched and breaks. The system defaults to door open when the wiring is broken. I just went through this with my 2013 F150 Screw..
https://www.ford-trucks.com/forums/1...ease-help.html
Old Oct 5, 2018 | 05:46 AM
milkman713's Avatar
milkman713
Supercrew cab
Thank you for your response.
I checked the wiring harness in the door all the way to the connection at the body. Nothing looks damaged or out of place. As a precaution I ordered a new harness. Was only $52 online. When it arrives I will install it and hope it works..
Old Oct 8, 2018 | 06:46 AM
milkman713's Avatar
milkman713
Rear door light on dash
Thank you calvynandhobbs I installed the new harness and it works perfect.
Old Oct 8, 2018 | 07:34 AM
calvynandhobbs
Glad to hear it worked. I found the info originally here also when I was having the same problem.
kbangus
Feb 9, 2016 09:45 PM
young ford man
Jun 6, 2015 04:43 PM
sidwaz
Electrical Systems/Wiring
Feb 17, 2009 09:56 PM
miker67
Jun 10, 2007 09:20 PM
