Sponsored by: Real Truck
Where's the connector?!?
Old Jun 10, 2007 | 07:49 PM
miker67's Avatar
miker67
O.k. guys, I am finally getting around to breaking down the 02-F350 project truck. I am in the process now of stripping the good stuff off the cab so that I can transfer it to the donor cab. The specific problem I am having is that I can't seem to find a connector in the door wiring harness that will let me separate the door from the cab, while still leaving the door harness on the door. I know one of you guys has to know what the scoop is. When you remove doors, do you have to pull the harness out the side of the truck and just let it dangle? That doesn't seem right. Every other harness can be broken down in between the main harness, and the sub harness for whatever it controls. Many thanks in advance!!
Old Jun 10, 2007 | 09:01 PM
ReAX's Avatar
ReAX
I think they are all in the kick panel. I haven't had to pull of any doors, but my superduty has a gang of plugs behind the kick panel trim.
Old Jun 10, 2007 | 09:15 PM
miker67's Avatar
miker67
Yeah, that was my thought too, but when I pulled the driver's side panel, there is so much stuff in there I can't even feel the wire coming through the grommet into the interior portion of the cab. There is the e-brake as well as the hood release hardware jamming everything up. I guess it might be a bit easier to see what's what on the passenger side, I just havn't gotten that door open yet. I am gonna have to do a little sawzall work to get that side freed up.
Old Jun 10, 2007 | 09:20 PM
ReAX's Avatar
ReAX
You should see everything going to the door gromet. I think they all trace down to that gang, but as you see they aren't all easy to get to.
