Anyone running 18s with 35s?
Hey I am about to buy a set of 18x9 inch wheels and 35s. I have read elsewhere that you shouldn't go smaller than 20s for our truck with 35s. Any truth to that? Anybody running 18s with 35s?
I'm also going to be doing the ats x and modded c springs at some point. Thanks!
Not sure why someone would say that you shouldn't go smaller than 20's for 35-inch tires. I have a set of 35's on 18's sitting in my shop, and they only have an inch more sidewall than the factory tire size on factory 16-inch rims. There are a lot of people here running 35's on 18's. I guess I don't understand what the problem is claimed to be...
Well, it is true to an extent that the less sidewall you have, the less sidewall flex you will have- but other factors come into play as well, such as how one manufacturer constructs their sidewall versus another manufacturer, the age of the tires, the tire pressure, how it is driven, was the correct load range observed for the vehicle, etc. But like I said, 35's on 18's is only about an inch more sidewall than the factory tires on 16's.
People ran around for decades putting 44 inch mudders on 15-inch rims. They weren't building them to be canyon carvers, but no one was hurt simply through the act of installing tires with 14.5 inches of sidewall. How they drove them is what made the dirty side point up.
For comparison, factory 265/75/16's have roughly 7.8 inches of sidewall. 35's on 20's are close with about 7.5 inches of sidewall. A popular "no lift" tire upsize is 285/75/16 with roughly 8.4 inches of sidewall. 35's on 18's are close to that with about 8.5 inches of sidewall.
yes less side wall flex and arguabley better handling but the side wall flex is also part of the suspension so ride quality suffers the larger the rim.
Was the guy telling you that about the 20"s also trying to sell some 20" wheels or tires?
I am another one that has been running 35"s (305/70R18 at 35.28") on 18"s (18"x8" OEM '04 Lariats) for years. My EX is a dedicated tow rig for a very large TT and has over 6,000lbs on the rear axle while hitched, these 35" Nittos have exhibited no troublesome sidewall flex or unwanted tire performance issues in the 22K towing miles they have seen.
No problem, just remember that going up in tire size will drive your effective gear ratio down numerically robbing you of some "tractive power" at the wheels. I think I recall your EX having the 7.3, so its not as much of an issue as the gassers, but something to keep in mind especially if some heavy towing is in the future plans.
I think that covers it? Any other advice is welcome. Thanks again fellas!
Your vehicle will make the same power with diffrent size tires but because the increased diameter means the engine will be turning at a slower RPM at a given speed. the rpm range where your engine makes the power may no longer be in the same range you need it most. The OEM setup matches the engines torque and HP output with the gear ratios and tire size. If you change one or more of those variables then You are changing the performance charteristics of the entire design.
The main reason mpg decreases with larger tires is you have altered the aerodynamic profile of the vehicle. When you increase the ride height off the ground more air is going under the vehicle which aerodynamically is the dirtiest part of a vehicle, the increased drag results in a decrease in mpg. Increased mpg is possible with taller tires because you can design in a decrease in rolling resistance but that isn’t what is happening with a typical installation of larger tires.
