My transmission will not go into gear. I can shift the automatic shift selector from one drive all the way to 1 with no response. I checked the linkage at the steering shaft and it is moving. The truck acts like it is in neutral the whole way through the shifting. When I get it back to Park it makes a grinding noise. This is on a 1978 F-150 4x4 with a c-6.
Thank you. I will check this out. I do remember moving the shifter while working on another area of the truck. Knowing me I have mis, momentary ignorance syndrome...... I probably did not get it fully engaged back into 2wd. I will check this tomorrow....
