Help troubleshooting 4x4 electrical
Old Sep 30, 2018 | 05:32 PM
Dale Wiggins's Avatar
Dale Wiggins
Bought an old 2005 and can not get the 4x4 to engage. Replaced the vacuum hubs and transfer case shift motor. When I turn the dash switch, the two relay switches click but the dash light doesn’t come on and the shift motor doesn't activate. The fuses all look good. I'm trying to find what the voltages should be at the relays and shift motor connector.
Thank you for any suggestions, winter is coming..
Old Oct 1, 2018 | 05:55 AM
projectSHO89's Avatar
projectSHO89
See the Sitcky Threads above that say READ FIRST.
Old Oct 1, 2018 | 10:09 AM
alloro's Avatar
alloro
The contacts inside the shift motor control the dash lights, so solve the shift motor not working issue and the dash lights should start working. To answer your question, the 2 relays have 12 volts on the contacts. See the attached PDF for the wiring diagram.
File Type: pdf
Old Oct 16, 2018 | 05:57 PM
nddragon01's Avatar
nddragon01
You're sure it's not the solenoid on the firewall behind the battery? Very common, cheap, easy fix.
dtherrien
1997 - 2003 F150
Oct 19, 2014 04:09 PM
BDTMTGT
1997 - 2003 F150
Jan 29, 2013 02:36 PM
Capester
Nov 24, 2010 12:47 PM
imabaka
Jul 26, 2010 09:01 PM
mallardmission
1983 - 2012 Ranger & B-Series
Dec 31, 2008 06:16 PM
