Sponsored by: Real Truck
Engine overheating
Old Sep 29, 2018 | 05:31 PM
B.Prins's Avatar
B.Prins
Engine overheating
Hi,, i'm having an overheating problem with my 2005 f250 superduty. Had my radiator checked, new thermostat, new water pump and new belt. As for the fan clutch a mechanic “ checked this while of the engine, by turning the bolt on the clutch” and told me the fan clutch was ok.
Now i placed the fan back on and realized the fan is really stiff to turn by hand and after turning a bit, it starts spinning more and more freely until its just completely freespinning. Is this normal or should i replace the fan clutch?
Thanks for all advice.
Old Sep 30, 2018 | 06:07 AM
Chuck's First Ford's Avatar
Chuck's First Ford
replace the fan clutch..
only test for a fan clutch is under POWER.. pulling lots of air while HOT...
just like the only test for an Engine.. does it Run and does so correctly..
Old Sep 30, 2018 | 08:56 AM
Djosbun's Avatar
Djosbun
What Chuck said.
Also, make sure the fan shroud is there and secured correctly. The shroud plays a major difference in cooling efficiency and a vehicle can overheat if the shroud is missing or was removed.
— Dave
Old Sep 30, 2018 | 12:19 PM
Chuck's First Ford
Originally Posted by Djosbun
What Chuck said.
Also, make sure the fan shroud is there and secured correctly. The shroud plays a major difference in cooking efficiency and a vehicle can overheat if the shroud is missing or was removed.
— Dave
THAT ALSO... its a designed system.. not just a few parts... and shroud gaskets... are they there.. and in good condition
Old Sep 30, 2018 | 07:48 PM
B.Prins's Avatar
B.Prins
Thanks Chuck and Djosbun.
Shroud is there completely and secured correctly. This truck came from Miami and is now in Curacao (Caribbean.) I just wanted to be as sure as possible before i order another part. Importing parts from the US is expensive. The dealer over here will not sell you parts or work on your truck if it is not a truck sold by them. We only have one Ford dealer on the island.
I'll start by ordering a new fan-clutch and see if that helps. Thanks again guys.
B. Prins
fhon
Mar 10, 2017 04:52 PM
Ritory
Nov 22, 2010 04:02 PM
rangersvt04
1983 - 2012 Ranger & B-Series
Nov 2, 2007 12:27 PM
76BIG/ORANGE
Feb 8, 2006 09:35 PM
ERIC79XLT
Nov 28, 2003 03:09 PM
