Brake loss
Old Sep 28, 2018 | 08:27 PM
jjshan's Avatar
jjshan
Brake loss
Hey everyone. I have a brake problem on a ‘73 f-750. Lost all brake pedal today. Master cylinder has recently been replaced. I’m wondering if the booster is bad. I can hear the booster suck air when pedal is pushed. No leaks, full of fluid. What’s the best way to diagnose a bad booster? Or has my master cylinder failed again?
Old Sep 28, 2018 | 08:37 PM
SlikWillie's Avatar
SlikWillie
Even if booster fails, you should still have brakes. You just have to really stand on them. With all that you have. Make should your seat is firmly bolted down.
Sounds to me like your master cylinder has failed again. Did you properly bleed the mc to begin with?
Old Sep 28, 2018 | 08:52 PM
jjshan's Avatar
jjshan
Yeah I believe I bled them well. I will replace the mc and go from there. Thanks for your input
Old Sep 28, 2018 | 09:00 PM
mark a.'s Avatar
mark a.
I would try bleeding the master one more time before thrown in the towel on it.
Old Sep 28, 2018 | 11:37 PM
SlikWillie's Avatar
SlikWillie
You may have to bleed the entire system. If the lines have enough air in them, the brakes won't engage when pedal is pressed. Air in the lines will compress while liquid can not be compressed.
Old Sep 29, 2018 | 10:07 AM
EagleChief's Avatar
EagleChief
Did you bleed the new master before you installed it? There may have been enough air in it to cause your issue, even though your bled the lines after install. May try that, then bleed the lines again before you buy a new master cylinder.
Old Sep 29, 2018 | 03:54 PM
ranger140892's Avatar
ranger140892
Grumpy goat
Based on his response, I don't think he knows the difference between bleeding brakes, and bleeding the master cylinder. They're two separate tasks. I mean no disrespect JJ. Hell I probably installed 4 in my life before I figured it out.
You should bleed the master cylinder before you install it. Watch some youtube videos. That'll explain it better than words here on the forum.
Old Sep 29, 2018 | 05:32 PM
jjshan's Avatar
jjshan
Sorry for the slow response. Yeah I bench bled the master cylinder before installation. I guess I was probably a little vague on how recently the mc was installed. It’s been about 3000 miles ago. Brakes had been working fine up until now. I just wasn’t sure on diagnosing a booster problem. Ive rebled the lines and don’t have much fluid pressure. Just a trickle. Wheel cylinders aren’t blown or anything like that. From what I’ve learned here I’d say my mc went bad.
AbandonedBronco
1978 - 1996 Big Bronco
41
Jun 14, 2022 08:40 AM
Mbarnett2
Jul 4, 2018 09:00 PM
davlun
Jul 23, 2014 11:32 AM
atxF100
16
Jul 30, 2012 12:47 PM
1986stepsidef150
Jul 22, 2012 09:45 PM
