351w overhearing
Old Sep 27, 2018 | 07:48 PM
Gigemags05's Avatar
Gigemags05
351w overhearing
Full disclosure: this is an 82 351w in a 47 ford truck with an electric fan that has a singe terminal temp sensor located in the thermostat housing. Motor has been slightly built with cam, intake, carb, and headers. All parts of the cooling system are new.
ive only had this thing on the road for a few months while I’m working out all the kinks. I typically drive it a few times a week for 15-30 min at a time. Twice now, I’ve been driving for 30 min plus and the temp has crept up to 230 (according to aftermarket gauge). One time the radiator overflowed/burped coolant.
Both times it’s gotten hot, it seems the electric fan has been running at about half speed and is going in/out. I replaced the temp sensor for the fan (located in thermostat housing) and the fan relay. I also replaced the 195 degree thermostat with a 180 degree thermostat.
Could the fan running weak/intermittently cause it to overheat like that? I assume so.
I checked all the electric/wiring on the fan and all seems to be good. It’s almost like there is hot water pulsating through the thermostat housing causing the sensor to read hot and make the fan run, then read cool and shut it off.
Could this be be a sign of a head gasket being installed backwards? There are tabs sticking out of the front of the heads, and I thought I installed the gaskets correctly, but there’s always a chance I messed up.
Old Sep 27, 2018 | 08:04 PM
Gigemags05's Avatar
Gigemags05
I’ve read that you can tell that a head gasket is installed correctly if there’s a tab sticking out of the front. I have tabs sticking out the front of mine but would like to confirm this is what I should see.
Drivers side
Passenger side
Old Sep 27, 2018 | 08:14 PM
kr98664's Avatar
kr98664
I’ve never been a big fan of aftermarket electric fans, but I’ll save that for another day.
A quick check for a problem with cooling airflow through the radiator: Does all seem good above 30mph? Does it heat up below that speed? Above 30mph or so, you’ve typically got good ram airflow through the radiator. That should help determine what’s happening.
Another quick thing to check. There’s a short 90 degree hose between the water pump and intake manifold. It’s super easy to kink this hose shut during installation. If pinched shut, it can cause general wonkiness with the thermostat behavior.
Old Sep 27, 2018 | 08:20 PM
Gigemags05's Avatar
Gigemags05
I also would prefer to use the factory fan but I didn’t have enough room in the engine bay.
Both times it’s overheated have been in slower traffic. In fact, same time of day at same location after similar drive times.
That 90 degree hose could be the issue.
I see there is a 90 degree bypass hose and a curved one. Is the 90 degree the one I need? I’m not sure which one I have but it didn’t make the angle all that well.
Old Sep 27, 2018 | 10:58 PM
kr98664's Avatar
kr98664
I have no idea of the difference. I thought they were one and the same? Make sure whatever you get is molded for the tight curve. Seems somebody on the forum recently ended up with a short piece of straight hose one was supposed to bend to fit. It didn't work, even though it appeared to fit okay.
I simply went to my local NAPA and asked for the little bypass hose between the water pump and the intake manifold. They had one sitting on the shelf. I think this was it, but am not positive:
https://www.napaonline.com/en/p/NBG7713?interchange=1
More options:
https://www.rockauto.com/en/catalog/...pass+hose,2155
Old Sep 27, 2018 | 11:04 PM
matthewq4b's Avatar
matthewq4b
If the bypass hose kinked it could cause issues. But once the stat is open it should not matter. A factory molded bypass hose is available in either the 90° one or the curved one.
https://www.rockauto.com/en/moreinfo...121588&jsn=471
https://www.rockauto.com/en/moreinfo...401231&jsn=555
We need pics to see what one you need. .
As for the over heating few possible things.
The rad fan could be not moving enough air.
You have the wrong rotation water pump installed.
The rad is restricted.
Old Sep 28, 2018 | 05:14 AM
Number4's Avatar
Number4
Does the radiator have a fan shroud? I’m other words, does the air have to go through the radiator via the fan? Or can the air flow through the radiator without going through the fan?
Old Sep 28, 2018 | 06:01 AM
Gigemags05's Avatar
Gigemags05
I don’t have a shroud on the radiator. Do I need to fabricate one?
Old Sep 28, 2018 | 06:58 AM
Number4's Avatar
Number4
Yes, you can research the effects of not having one.
Also, what side of the radiator is the fan mounted? And do you know if it’s a pusher or a puller?
Old Sep 28, 2018 | 07:19 AM
FuzzFace2's Avatar
FuzzFace2
Also the lower radiator hose, suction side of water pump, needs to have a spring in it to keep it from closing shut when at speed / RPM.
Dave- - - -
Old Sep 28, 2018 | 07:32 AM
Gigemags05's Avatar
Gigemags05
Okay,
I will try to figure out some sort of shroud. Any ideas on that? I'm afraid it may be hard to find one since my application is custom.
I do not have a spring in the lower hose. Its one of those flexible radiator hoses because none of the pre-molded ones would fit. Do I need to get a spring to put inside of it? If so, where would I find one of those?
The fan is a puller. Its mounted inside the radiator. When it is running full blast, its moving a lot of air in the engine bay. Both times its been really hot, its only been running half/intermittently.
Old Sep 28, 2018 | 07:39 AM
Gigemags05's Avatar
Gigemags05
Question on a fan shroud: The fan is mounted directly to the radiator. I only have about 1/2" of clearance from the crank pulley. I assume if I build some sort of shroud that I would need to back the fan off of the radiator to allow the shroud to funnel air to it? If so, I think I may have an issue there.
Old Sep 28, 2018 | 07:40 AM
Number4's Avatar
Number4
Have you run it at night with lights in? Wondering if the lights dim while at idle and it’s not spinning as fast. Could be that your alternator at idle can’t keep up with the power need. Could be.
I’ve done my e-fan installs with the OE fan shrouds in mind.
or made sure the fan I used, had a sufficient enough stock shroud to cover the radiator.
You’ll find in some cases where people have used aluminum or tin, to cover any exposed parts of the radiator not covered by the fan.
Old Sep 28, 2018 | 07:48 AM
Gigemags05's Avatar
Gigemags05
No, I haven't driven it with the lights on. I have a 3G 130 amp alternator and my voltmeter stays above 14 amps.
Old Sep 28, 2018 | 08:14 AM
Gigemags05's Avatar
Gigemags05
Can anyone comment on the pics above of the head gaskets? Can I eliminate a mis-installed head gasket from the possible cause?
If the gasket was on backwards, wouldnt it overheat pretty quickly?
