Bent Pushrod
Old Sep 26, 2018 | 11:52 AM
Rustyol79's Avatar
Rustyol79
Bent Pushrod
I have a rebuilt 300 in my 1979 F-150 4x4 with less than 7,000 miles on it. I was hauling a truck home on my trailer Monday when I noticed the truck sounded different. I drove the truck to work yesterday morning and it ran progressively worse. I made it back home (barely), took off the valve cover and found #5 cylinder exhaust valve stuck open, rocker arm off, and pushrod bent. I stuck a screwdriver in the spring and got the valve shut. I put a good pushrod in and retightened. I hope this was just a fluke and does not happen again. I was hoping someone has some advice on this. Thanks, Tim!
Old Sep 26, 2018 | 09:08 PM
The Frenchtown Flyer's Avatar
Originally Posted by Rustyol79
... I stuck a screwdriver in the spring and got the valve shut... I was hoping someone has some advice on this. Thanks, Tim!
If you had to pry the valve shut by leveraging the spring there is a good chance the valve is bent. When the rocker cocked this is a possibility. If you run it with a bent valve it may ruin the valve guide. Better check it out.
Marneaus
21
May 6, 2019 11:40 PM
daddy172005
Apr 13, 2009 11:58 PM
phillips91
42
Apr 5, 2009 12:03 PM
original67
Sep 23, 2004 05:05 PM
sdloe
13
Jan 5, 2004 02:49 PM
