Maine Chapter Join Chapter , Leader:
Anti-Gel??
Old Sep 25, 2018 | 11:28 AM
VA13FX4's Avatar
VA13FX4
Anti-Gel??
I'm new to Maine and new to diesels! I'm shocked that it's already getting into the 30s at night!!!!
When do I need to start adding anti-gel to my fuel?
Old Sep 25, 2018 | 04:16 PM
seville009's Avatar
seville009
The diesel you buy at the gas station should be blended for winter, so you really shouldn’t have to do anything. That being said, in my diesel equipment (tractor, skidsteer), I always add the white bottle Power Service Diesel Clean to my diesel containers when I fill them up. I also keep in hand the red bottle Power Service 911 in case I do get gelling.
Even in below zero temps, my skidsteer has never gelled. My tractor has, but it has a smaller fuel filter that sits outside the engine.
Should also have a few extra fuel filters in case you ever do get gelling.
Old Sep 25, 2018 | 05:58 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
If your shocked with 30's,just wait until a couple months when it's well below zero and we get our first Nor'easter.This is warm and mild compared to what's coming lol.Welcome to Maine.
Old Sep 25, 2018 | 07:32 PM
VA13FX4's Avatar
VA13FX4
please just stop
you’re scaring me
Old Sep 25, 2018 | 07:39 PM
FORDF250HDXLT
Originally Posted by VA13FX4
please just stop
you’re scaring me
Far better to be prepared than to be blind sided lol.
I don't stick around in that mess anymore.I pack up and head out west.Had enough of these dang Maine winters.Out in Oklahoma,it's cheap living,sunny and mild winters generally.Last year wasn't the t-shirt weather like normal but still mild compared to here.
It get's nasty bud.Real nasty.This and low jobs keeps it rural and real nice though.
Old Sep 28, 2018 | 06:27 AM
ToMang07's Avatar
ToMang07
We've had October storms in the 20's+ inches before. Welcome to Maine, lol
That said, I tend to add it once the temps start hitting the 20's and below. When it starts getting to the negatives, I double up dosages just to be safe. I run Power Service, Grey in summer, White in winter.
Old Oct 1, 2018 | 04:58 PM
VA13FX4's Avatar
VA13FX4
Coming from California, I don’t have a block heater. My garage is attached to the house but not insulated. Think it will get cold enough that I need to buy a block heater?
Old Oct 1, 2018 | 05:59 PM
seville009's Avatar
seville009
you might already have the block heater. If the cord isn’t already there, you can just buy the cord and element and plug it in (because I think the spot to screw it in is there).
https://www.ford-trucks.com/forums/1...nection-2.html
My garage is unheated. The heat from the engine helps keep it close to 32 degrees with the doors closed. I have a torpedo heater to use though in case it does get too cold.
You should be fine without the block heater though. Strong battery is your friend.
Old Oct 1, 2018 | 06:58 PM
FORDF250HDXLT
I've never plugged either of my diesel trucks in to see if the block heaters work or not.With the dual batteries they just start.Unless they've been sitting for a while,then the batteries will eventually go down and might need a jump to get running but If I'm around home and running the trucks,it will just fire up and go.I think the diesels start easier than the gas because in the gas you don't have glow plugs.
Of course if something is wrong,like low batteries,burned out glow plugs,bad relay etc.etc. then your going to need a jump and or starting fluid,a hair dryer shooting down the intake and some claim a diesel will fire up off the fumes of a gasoline soaked rag,though I've never had to try it.
If everything is in top shape,they will start right up just the same as in summer.The advantage of plugging in,is you'll get heat in the cab much quicker but I dress so warm in the winter cus I despise the cold so much,it doesn't make a hill of beans difference to me lol.My rule is,if when I layer up and I'm not sweating inside a minute or two inside,then I need more layers before heading outside still.
Old Oct 5, 2018 | 06:01 AM
VA13FX4's Avatar
VA13FX4
Thanks for the info. It’s been 20 years since I’ve lived somewhere that had a real winter! And this is my first diesel ever.
CaptainFoMoCo
Jan 5, 2018 06:01 PM
Dakster
6.7L Power Stroke Diesel
Aug 15, 2016 06:14 PM
AKMKGUY
Oct 15, 2013 01:00 PM
msgtg
Dec 6, 2011 04:19 PM
mmusky1
Apr 19, 2001 08:26 AM
