trans question
Old Sep 25, 2018 | 10:23 AM
2020's Avatar
2020
trans question
This has probably been asked before. I have a 95 f150 4wd with a bad trans. It has a code "u" 4r70w. Will any later model trannys interchange?
Old Sep 25, 2018 | 10:41 AM
Conanski's Avatar
Conanski
Later model? You need a trans with SBF bolt pattern so that limits choices to vehicles with those engines which except for the Explorer ended in '96.
But before going there what kind of problem is the trans having? These things are computer controlled and can do some strange things when sensor and wiring problems are encountered.
Old Sep 25, 2018 | 10:44 AM
2020's Avatar
2020
I have been told that the 4.2 engine had the same bellhousing. That may give me more choices at the boneyard if true.
Old Sep 25, 2018 | 10:46 AM
Conanski's Avatar
Conanski
The trans has to be 4wd to be a direct replacement too.
Old Sep 25, 2018 | 11:14 AM
2020's Avatar
2020
Hopefully a 4.2 4wd will give me more choices. Just a 95-96 OBS truck may make it harder to find a replacement
texinwa
6.7L Power Stroke Diesel
Dec 10, 2017 04:50 PM
1320stang
1997 - 2003 F150
Dec 31, 2015 07:34 PM
j250hd
Apr 14, 2010 03:57 PM
f150guy88
Mar 4, 2009 05:19 PM
SANDDEMON08
Jul 29, 2007 02:13 PM
