Sponsored by: Real Truck
Tire pressure warning
Old Sep 24, 2018 | 03:05 PM
William Blankinship's Avatar
William Blankinship
Question Tire pressure warning
Low tire pressure warning came on. I have a 2015 Ford F250 I bought 2 months ago.I have 52 plus PSI in the tires. The spare is hard but I am not able to check pressure on it without taking it down. Should the warning be on at 52 PSI?
Old Sep 24, 2018 | 03:53 PM
NWnative's Avatar
NWnative
Check the door sticker to see where tires should be at. On mine it's 60psi front and 65psi rear. The spare does not contain a sensor so it would have to be one of the 4 mounted tires. Not sure at what PSI the system sends an alert but, your definitely below recommended PSI. Might check the rear tires first.....
Old Sep 24, 2018 | 04:58 PM
Chuck's First Ford's Avatar
Chuck's First Ford
agreed...
my truck front is 65..... and rear is 80...
so low light comes on front about 55.. and rear about 70.....
so when I rotate tires.. I must reprogram unit...
no sensor in spare..
Old Sep 24, 2018 | 06:54 PM
82_F100_300Six's Avatar
82_F100_300Six
I had a warning for like two months....started at the end of December. I had plenty of air. Man it was annoying but I stood my ground and it finally gave in and quit.
Old Sep 25, 2018 | 04:22 PM
William Blankinship
Come to find out my tires are Goodyear C rated and not E rated. 50 psi is max on these tires. I bought the truck used and they may have switched out the tires before they traded it in. What I get for buying used. :-)
Is there anyway to lower the setting on tire pressure warning?
Old Sep 26, 2018 | 07:16 AM
Chuck's First Ford
if you are going to "WORK" the truck.. upgrade the tires...
No, you can not change the value of the tire pressure warning system...
I got my truck "USED" and it had replacement "E" tires... as I got a work fleet/lease truck...
Old Sep 26, 2018 | 09:50 AM
William Blankinship
buyer beware
Your would think at 73 and as many new and used truck I have bought that I would have caught this. Oh well......
Old Sep 26, 2018 | 11:17 AM
River Wild's Avatar
River Wild
Actually you can change the setting but it requires a laptop, FORSCAN, and a plugin to the OBDII port.
Click here for more info -> FORSCAN Thread provided it will work on a 2015.
Yeah I'd upgrade the tires however but even with "E" 60/80 psi is too much. I run 50/70 and hope to lower that once I get the forscan set up.
Old Sep 26, 2018 | 11:31 AM
William Blankinship
Thanks for the information. I will keep at 50 psi. I do not haul or pull really heavy loads great distances. I will upgrade to E rated tire in the near future.
Old Oct 4, 2018 | 06:08 AM
William Blankinship
Well, I fixed my problem. I bought me a new set of Cooper E rated tires :-) Problem solved :-) Sold old tires to a used tire dealer.
Old Oct 16, 2018 | 01:40 PM
82_F100_300Six
Well my truck didn't take long to react to fall....the very first day we have here below 70 and lower humidity and it goes off
Old Oct 16, 2018 | 02:22 PM
INTP's Avatar
INTP
I went into Forscan on my 18 F250 and turned the tire pressure monitoring system off. I mostly haul sailboat fuel so I like to keep the tires aired down to help with the ride.
Old Oct 16, 2018 | 06:38 PM
82_F100_300Six
Thanks sounds like a plan
I continued on my way a couple hundred miles and did a walk around a few times.... another false alarm it seems.
I just got back but haven't actually put a gauge on any of them yet.
the thing is I run plenty of air pressure it's not like I'm running right at the edge. So....idk.
Old Feb 19, 2019 | 05:30 PM
William Blankinship
Tire pressure low warning came on. Had tire place check tire pressure and set to 60 front and 70 back on my E rated tires. What is the reset procedure?
Old Feb 20, 2019 | 06:43 AM
crewzer's Avatar
crewzer
Once the TPMS warning light illuminates, you may need to set cold tire pressures at/above factory recommendations to turn off the light, and you may also have to drive a short distance to activate the sensors. Once the light is off, then you can drop the tire pressures a bit.
The actual trigger value appears to vary by truck model, tire size, and configuration. Our truck’s factory pressure specs are 55F/80R, but, for driving around lightly loaded, I have the tires set at 50F/65R cold with no apparent TPMS issues.
HTH,
Jim / crewzer
