Lack of gas
Lack of gas
whats the easiest way to get gas to fill the carb bowl when empty? Seems like gas keeps draining from bowl when it’s sits for a few days. When it is full, truck runs great.
also, now with the new tank installed, it seems like a hard draw (take inlet on fuel pump off, suck on the line and it it takes a lot to pull gas through. I’ll have to check, maybe I have a kink in the line or the filter on backwards.
Wow! I hope not. 1/4" NPT valve at the tank and 5/16" tubing is standard up to the 1/4" jumper hose to the fuel pump, and 1/4" or 5/16" from the fuel pump to the carburetor. Better double check that size. The cap does not have to be vented if you are using the vent fitting on the top of the tank.
Just measured a piece of the copper line I cut off. ID is 1/4. I’m thinking the fitting coming out of the tank is restricted. It’s the only fitting NAPA had that screwed into tank and went to a barbed fitting. The back hose I used actually fits snugly over the copper pipe and held in place with clamp.
Copper tubing is measured by the outside diameter (OD) and the wall thickness. So if you have tubing that has a 1/4" ID, it is measured as 5/16" tubing with a .0625" (1/16") wall, which is considered a heavy wall tube.
I think I know the fitting you're talking about, it's only 1/8" ID
You should have a valve like this on the bottom of your tank, and not just a 90 degree fitting to a hose.
https://www.zoro.com/zoro-select-bra...BoCASsQAvD_BwE
