Sponsored by: Real Truck
P1131 and P1151 codes
Old Sep 22, 2018 | 11:42 PM
tommy919's Avatar
tommy919
Hi all,
I'm new and not sure how to correctly navigate this place yet, so forgive me if this is something that has been posted many times and I'm to dumb to find it.
I have a 1999 F250 SD 5.4 that has been giving me a fit, the 1131 and 1151 codes just don't tell me enough , one day the truck was running fine, the next it was like crap, it was that abrupt. It runs better when cold, and when at normal temp it really stumbles at and above 2k rpm under driving load. revs fine when sitting still. It also seems to be worse when I have to sit at stop lights for long amounts of time, and if I shut the engine off and restart it it does better. So far I have only cleaned the MAF and tested it to make sure it was good, and checked for vacuum leaks, that I have not found any, dose not mean there aren't any I just have not found any. I have not checked the o2 sensors yet as I'm not sure on the testing procedures yet, any help with those would be appreciated, or any other ideas on what I should look for to get me going again. Thanks!
Old Sep 23, 2018 | 07:03 AM
02TB250's Avatar
02TB250
Did a google search and this popped up and seemed to mimic your situation. From reading this it seems the 02 sensors aren't responding . You may want to test those or try replacing one of the upstream ones to see If you can get a code to go away. The thread also indicated it potentially could be the wiring harness or ecu. Give the thread a read. Wish I had more concrete help for you.
https://www.obd-codes.com/forums/viewtopic.php?t=16493
Old Sep 23, 2018 | 10:24 PM
tommy919's Avatar
tommy919
Thanks for the link, I am trying not to just throw money/parts at it in hopes of fixing it , but I think I may end up having to buy new o2 sensors as they are a pain to test , I went though the top side of the engine again today searching for vac leaks and all is good, so it is something in a sensor somewhere.
Old Sep 24, 2018 | 10:55 PM
tommy919's Avatar
tommy919
Well it was the oxygen sensors, if anyone is looking for a good price on them then head over to Amazon, I had the two of the with free next day shipping for less than I could have bought one for at Advance auto, now my truck runs like it was before this, I have no idea how both sensors went at the same time but it's done now.
Old Sep 25, 2018 | 05:53 AM
02TB250's Avatar
02TB250
Glad to hear it worked out. Thanks for updating us.
rogerranger2122
1983 - 2012 Ranger & B-Series
23
Aug 8, 2016 06:24 PM
OL FT
Sep 7, 2012 08:57 AM
steinoles
Oct 18, 2008 12:19 PM
tm3912
Jul 27, 2007 11:13 PM
nightme_02
Jul 28, 2005 10:35 PM
