over heating with lean codes
Old Sep 6, 2012 | 09:12 PM
OL FT's Avatar
OL FT
I just bought my 'new' 96 4.9 4x4 xl a couple weeks ago. I knew it had a egr code, and secondary air code, air tube is broke, all other monitors were set. I only drive the truck about 15 miles a week and was driving fine the first 3 weeks I had it.
The other day coming home around 55-60 mph hit a bump and she stalled out. Started right up while coasting in neutral with no other issues. The next day it happened again and started to over heat. Now she has bank one and bank two lean code. As well as the other codes.
I only have a code reader and can't read the fuel trim or KAM info. Just need a nudge in the right direction to help figure out what's going on. I don't know why or if the new lean codes have to do with the over heating issue. No visual coolant leaks. And runs fine until I hit a bump while accelerating.
Old Sep 6, 2012 | 09:31 PM
danr1's Avatar
danr1
Get under it look at the wires to the 02 sensor?
With it idling wiggle sections of the harness, see if you can find a "tender spot" part of the harness where you get a definite reaction to shaking the wires around.
If find one you know where to concentrate your efforts. If has no effect might be something little more drastic.
Oh and make sure the battery is tied down/isn't too tall for truck, positive post isn't hitting hood when hitting bumps in road.
Give the whole thing good visual going over, make sure no fuses are blown etc etc.
Old Sep 6, 2012 | 10:56 PM
OL FT's Avatar
OL FT
I didn't even think of the battery. I noticed it was missing the hold down when I bought it and thought it could wait till I fixed the exhaust.
Awesome, thanks for you input. Any insight into the lean codes and over heating issue?
I'm gonna fasten the correct battery in the truck n clear the codes n see what happens. I read that the truck could run over heat with lean codes. I gonna try to find a scanner that will read the MAS, but until I can I just bought some $30 cleaner and plan on cleaning this weekend. I also looked for vacuum leaks and haven't found any. Sprayed everything down w carb cleaner and no change in idol. The PCV valve, grommet, and hose are new. The throttle body and intake gaskets don't appear to have any leaks.
I appreciate the feed back.
Old Sep 7, 2012 | 08:10 AM
mpc07005's Avatar
mpc07005
Your lean problem is your overheating problem. Things to check:
1) Electrical. (like danr1 said) This is all the sensors and wiring, but focus on the O2 sensor, MAF, and wiring. Also check your ECT sensor.
2) Fuel pressure. The computer times injection pulses based on a (roughly) known pressure, too little pressure=too little fuel
3) Firing order/timing/valves. Probably not this, but could cause your symptoms. Ignore this till you rule out everything else.
You seem to have a global problem, and given your configuration I would not suspect the Injectors/associated wiring. First off, make sure all your sensors are plugged in, then try the shake test danr1 suggested, then pop a gauge on your fuel rail and clean your MAF. Do you know how old the HEGO (O2 sensor) is?
-Mike
Old Sep 7, 2012 | 08:57 AM
OL FT's Avatar
OL FT
Awesome. Thank you guys. Big help. @mcp haven't checked the O2's yet. Gotta find time this weekend. Thanks again
Stevil
3.8 & 4.2L V6
May 2, 2012 06:55 AM
obnovas1996
May 11, 2010 10:06 AM
ram10
Modular V10 (6.8l)
Feb 6, 2008 11:59 PM
Will_01_GT
Jan 6, 2005 03:03 PM
SHOpar
1983 - 2012 Ranger & B-Series
Mar 31, 2003 08:59 PM
