No spark
Old Sep 21, 2018 | 08:13 AM
elkhunter0452's Avatar
elkhunter0452
No spark
Finally after removing the spark plugs from 2007 Lincoln Mark LT 5.4 engine 4 WD crewcab, which is basically a Ford engine. Replaced new plugs and coil packs and still runs rough. I pulled all the coil packs and plugs and found that the plug on the passenger side and of course farthest back doesn't appear to be firing. I took my meter and checked the coil pack plugs for voltage and each show 12 volts . I made sure the plug boots were were inserted to the spark plugs tightly as well as the electrical connector. Tried it again and same thing runs rough. Is it possible I got a bad plug as when I pulled the old ones out they all were firing by the looks of them.
Old Sep 27, 2018 | 09:34 AM
varminthunter243's Avatar
varminthunter243
I've had bad brand new plugs a few times throughout the years. Swap it with a cylinder that's easier to get to and see what you get. May wanna check that injector too.
Old Sep 27, 2018 | 09:58 AM
alloro's Avatar
alloro
It's never the easy to reach one, is it?
leftylucy64
2004 - 2008 F150
Jul 7, 2020 08:26 AM
thesnookman
Modular V8 (4.6L, 5.4L)
Feb 27, 2017 02:57 AM
Watcher58
Aug 20, 2015 04:31 PM
luvcycles 2
Modular V10 (6.8l)
Jun 4, 2010 09:19 PM
Pastmaster
Jun 7, 2001 11:24 AM
