Electtonic Overhead Display
Old Sep 19, 2018 | 09:37 PM
Richwon4's Avatar
Richwon4
Not sure what is going on with my overhead display. It worked intermittently for a month now I get nothing. Anyone else have experience with this?
Old Sep 19, 2018 | 09:42 PM
Flyboy1100's Avatar
Flyboy1100
Fix is in the tech folder, most likely resistors are unsoldered
i need to tackle mine when i get home in 10 days
Old Sep 20, 2018 | 04:18 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Circuitboardmedics.com
Affordable, good work and they are a sponsor here.
Old Sep 20, 2018 | 05:34 PM
01__Excursion's Avatar
01__Excursion
I had an issue with the display going dim, I would fist the ceiling console, and it would go bright again. Took it down twice and inspected, found nothing, re flowed all the larger solder joints, plug connectors Etc, still no-go. Deliberately re-flowed all the solder joints to the SMT resistors, and no issues since. So one of those had an undetectable crack in the solder.
Old Sep 21, 2018 | 07:57 PM
yzf450motoxrider's Avatar
yzf450motoxrider
mine seems very dim cant really see it in day time. ill have to try what you described above.
Old Sep 21, 2018 | 08:40 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
If it is dim, then the resistors are coming unsoldered. They will eventually fall out, and you will lose the whole display.
Old Sep 22, 2018 | 06:25 AM
wallerus's Avatar
wallerus
I had mine done by a place on eBay, by rapid electronics, $25 + $4 shipping. Got it back in a few days all fixed.
Old Sep 23, 2018 | 10:27 AM
chetspencer's Avatar
chetspencer
Do you guys know if a blank compass is caused by the same problem. I already resoldered the resistors back on and my lie-o-meter works, but no compass.
Old Sep 23, 2018 | 05:24 PM
01__Excursion
Did you go to the compass setting and try a re-calibration per the owners manual? Just a thought...
Old Sep 23, 2018 | 06:28 PM
chetspencer
I'll give it a try, thanks
Vinford
Jan 12, 2016 03:59 AM
utjer
Mar 3, 2011 03:21 PM
Red Monkey
33
Mar 4, 2008 04:50 AM
expi2004lexdeb
Jul 23, 2004 07:26 AM
