Camera operation
Old Sep 19, 2018 | 11:48 AM
Mlambert22's Avatar
Mlambert22
Camera operation
I'm looking at the Naviks system to operate my cameras while in motion..
https://naviks.com/i-24075930-2017-2...tegory:1137501
Is it worth the $450? Is it a pain to operate?
Old Sep 20, 2018 | 10:35 AM
Mlambert22's Avatar
Mlambert22
Has anyone used this and is it worth the money?
Old Sep 20, 2018 | 10:56 AM
desmo21's Avatar
desmo21
The unit fools the truck into thinking it is in park. This messes up the Navigation (FORD). If you use waze it works fine. The FORD carms work at any speed. The turn signal camera is usefull. If you have the FORD trailer CAM installed on your trailer you can aslo see that at any speed instead of factury setup of backing only.
Old Sep 20, 2018 | 11:02 AM
desmo21's Avatar
desmo21
If you look at your attached video you will see the red arrow on the navigation screen is of the road. That is what happens to the navigation.
Old Sep 20, 2018 | 11:24 AM
stufarmer's Avatar
stufarmer
Much appreciated .. but $450. seems a bit spendy for a wire harness. If it were a heads up display, I think I'd be more interested.
Old Sep 20, 2018 | 12:31 PM
Mlambert22's Avatar
Mlambert22
So if you use this unit you can not use the Ford navigation? Would you have to keep your phone plugged in and run Waze off your phone
Old Sep 20, 2018 | 01:30 PM
desmo21's Avatar
desmo21
You need to not use the factory NAV when using the camera. Waze will show up in the NAV screen and will operate properly. It is easy to turn ON/OFF the NAVIK system.
Old Sep 20, 2018 | 01:48 PM
Kaadk's Avatar
Kaadk
From the video, it looks like you need to do some kind of secret code to get it to activate? I'd like to be able to run my cargo camera sometimes, and especially my trailer camera, but I don't want to have to go through up, down, up, down, left, right, left right, b, a, b, a, start every time I want to use it.
Old Sep 20, 2018 | 06:48 PM
k7lvo's Avatar
k7lvo
I don’t have any problem using factory navigation with it.
Yes, $450 is a lot of money. Sometimes I have momentary buyer's remorse, but I’d miss it if I didn’t have it.
No secret codes. There the same for every unit. :-)
I’ve only had to set the turn signal camera operation once, but the camera-while-in-motion seems to reset every time the truck is shut down.
Incidentally, it also lets you program factory nav while the truck's moving.
Old Sep 20, 2018 | 07:47 PM
Mlambert22's Avatar
Mlambert22
Are the lights on the temp control and the rear defrost blinking all the time they are in operation?
Old Sep 20, 2018 | 08:47 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
you push volume button on the one for my xlt for 8 seconds, i wanted it for behind my toy hauler.
I added camera in the grill and above the back license plate when not towing. I have a small
round toggle switch to toggle front/back camera's. It's expensive but a great mod when backing up a 34 ft th!
https://naviks.com/i-24075739-2016-2...tegory:1137501
Old Sep 20, 2018 | 09:41 PM
Mlambert22's Avatar
Mlambert22
Do you have 2 cameras on the front and back now?
noticed the one for the 150 is cheaper than the superduty😢
Old Sep 20, 2018 | 10:38 PM
TXSD6.2's Avatar
TXSD6.2
I'd gladly enter that code if I could play Kontra on my 8" sync 3 display...
Old Sep 21, 2018 | 05:27 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
noticed the one for the 150 is cheaper than the superduty��
yes and it works with my 2018 sd, about 1/2 hr install. hard part is the video lines into the cab.
i bought these $20 licence plate camera's on amazon, it comes with button for choice of lines.
I have a 4 pin adapter for the back up camera because the toy hauler is 4 pin. Here are the on/off/on
switches im using on my work truck and the f250
https://www.amazon.com/gp/product/B01MR5X270/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B01MR5X270/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B073B193ZS/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Old Sep 21, 2018 | 08:32 AM
desmo21's Avatar
desmo21
Below is the email I received from NAVIKS regarding using the factory navigation system while operating cameras:
NAVikS
224 Kings Hwy
3RD FLR
Brooklyn, NY, 11223
The navigation system will not track properly when the cameras are being used in motion. If the cameras bypass is not activated or deactivated the navigation will track properly. Thank You
