1st Excursion
Old Sep 17, 2018 | 10:13 AM
Dolton916's Avatar
Dolton916
1st Excursion
After lurking here I bought a 2000 XLT V10 2wd, thanks to you folks I have fixed the a/c issues and the info center.
My question is it’s sitting on 305-85 20’s and I’m assuming has a lift of some sort. It has a small block in the rear and has bilstein shocks but would any other pics help to identify?
I just want want to level it. Thanks again for the help so far and I’m hoping someone can help with this
Old Sep 17, 2018 | 10:27 AM
EXSwap's Avatar
EXSwap
Welcome to the club! Clean looking X! I'm sure the local suspension gurus will chime in. Take some pics of the suspension including the block and springs and post up.
Old Sep 17, 2018 | 10:39 AM
Dolton916's Avatar
Dolton916
Will do when I get to the house tonight
Old Sep 17, 2018 | 12:25 PM
pirate4x4_camo's Avatar
pirate4x4_camo
RWD Ex did not come from the factory with a rear block. the springs are mounted directly to the spring perch..
Old Sep 17, 2018 | 12:27 PM
Flyboy1100's Avatar
Flyboy1100
Nice looking! I want to find a 2nd Ex this time in 2wd
Old Sep 17, 2018 | 12:33 PM
Dolton916's Avatar
Dolton916
thats what’s leading me to the assumption it has some sort of lift, that and 32” tall tires. I believe iirc the block is about 2”
ill get some pics when I get home
Old Sep 18, 2018 | 10:03 PM
Dolton916's Avatar
Dolton916
H
Here are a few pics of the suspension hopefully someone can identify the changes from stock. I’m happy with the rear but would like to level it.
Old Sep 18, 2018 | 10:30 PM
pirate4x4_camo
Yes it has had blocks added to raise the ride height.
hard to tell from the pics how much rake it has so if you measure from the center of the hub to the bottom of the fender lip both front and rear then we can figure out your rake as well as height change over stock.
to level it the best way in my opinion is to lower the back. After doing your measurments you can figure the exact height you want and order a set of custom blocks from PMF.
Ford F-250/350 Fabricated Lift Blocks
Old Sep 19, 2018 | 09:14 AM
Dolton916's Avatar
Dolton916
I’ll get measurements this afternoon, I would prefer to lift the front to match just for looks.
Old Sep 19, 2018 | 12:56 PM
rwebb's Avatar
rwebb
Did the 4wd come with a spacer blocks in the rear? I'm also a new x owner and trying to figure things out with my ride.
Old Sep 19, 2018 | 01:01 PM
Stewart_H's Avatar
Stewart_H
Yes.
Stewart
Old Sep 19, 2018 | 02:33 PM
WE3ZS's Avatar
WE3ZS
Welcome to the EX forum!
Start a new thread to show off your new EX and discuss exactly what it is that you are trying to figure out, lots of EXperience floating around in here, I'm sure we can help to sort it out with you.
Yes, the 4x4 EX came with a 2"-ish rear lift block. A good starting move when figuring out suspension questions is to get four corner measurement from the hub center to the wheelwell arch, that will tell you and us exactly where your suspension sits without the variances of the tires. Be sure to be parked on a flat and level surface for the measuring work.
Oh, and we do require pictures of the rig!
Old Sep 19, 2018 | 05:51 PM
Dolton916's Avatar
Dolton916
Front is 22” rear is 25”
Old Sep 19, 2018 | 07:09 PM
Markken's Avatar
Markken
I believe the front should be 23" at stock setup.
let one of the suspension guys say for sure but that sounds like you need new leaf springs up front from other threads on suspension i have read on here.
palacios289
Jan 4, 2025 12:55 PM
Alext1399
Mar 20, 2015 05:11 PM
locknload223
Jun 16, 2010 08:04 AM
dave91gt
Mar 24, 2010 02:02 PM
zstyle01
Apr 2, 2007 09:56 PM
