How hp/tq can a stock transmission handle?
I have a 97 Powerstroke that's mechanically sound (162,000 miles), and I'm looking to do simple, yet effective upgrades without burning up my transmission.
Parts List:
1: https://www.bankspowerproducts.com/B...em-p/46356.htm
2: https://shop.fullforcediesel.com/obs...ffdobsst15.htm
3: Probably new head studs.
Like I said -- Nothing crazy. I don't have a lead foot, but I also don't shy away from the usual "stoplight challenge". A bit of minor towing (car/horse trailers). All input is welcome.
Parts List:
While I dont have the experience with the 94-97 7.3s, I can shed a tiny bit of light on what you're looking at.
First off, if you've got a manual or an automatic will make a big difference on what it can handle.
1: You can more than likely piece together a kit at a better price than what Banks has listed there.
2: I recommend bumping to 80% nozzles over the 30% you have there. The 80% nozzles offer a good bit of advantages, many of which Tugly (Rich) has talked about previously, one post of these many can be found HERE. I also recommend new injectors vs reman. Look through some of Rich's posts and do a lot of reading up, it will not only increase your knowledge on the injectors themselves, but also help you make a better bang-for-the-buck decision.
3: I'm at 389k on my stock head studs running Stage 2 (160/80) sticks and a couple other mods, currently slipping a 400hp/800tq clutch with this setup. IIRC Rich made a couple posts regarding him installing ARP bolts without removing the head. May be worth a look for ya.
Parts List:
Parts List:
I would skip the banks too. You will still have to spend around $450 for a chip and custom tunes to run those injectors. That banks chip is for stock injectors. Exhaust, Intake, Chip+tunes, Gauges or CTS2, Intercooler (since you are OBS), check for boost leaks and maybe just get a full boot kit from Riff Raff. That would be a great setup with 160/80.
If not stock, what should I do? Clutch kit, rebuild kit, etc.?
https://www.dieselpowerproducts.com/...werstroke.aspx Maybe just stick with some stage 1 injectors?
If you are gonna go to the 180cc, then you might as well go with a bigger nozzle because these injectors will be custom built anyways. If you want, you can go with an AC code (160/0) that come from the international version of the engine, so they are a direct drop in with no modifications and can be purchased straight off the shelf at any international dealer. These will give a good bump in power and still allow max towing and they will always be available.
First of all get boost, egt, and trans temp gauges before you do anything, then for a good intake an exhaust the 6637 filter kit from riff Raff and a 4" Diamond eye exhaust are good options then you can get a Hydra chip for tuning, those mods alone will make a big improvement. If you want more than that things start getting expensive, bigger injectors, will require a built transmission, adding an intercooler, turbo upgrade, electric fuel conversion and 17* HPOP to run them effectively, you can do all of those mods one at a time with the bigger injectors being the last thing you do. Also avoid anything Banks, there is almost always a equal or better product available for cheaper.
The stock auto can barely hold up to a stock engine.
For the price of the banks kit you can get a t4 kit with turbo and have enough left over to get a nice used intercooler and a diamond exhaust
https://www.iratediesel.com/irdie/pr...5rwhp-package/
In this order
6637 intake
full ehaust
gauges
hpop
intercooler
push rods
stage I’s
turbo/intercooler
In this order
6637 intake
full ehaust
gauges
hpop
intercooler
push rods
stage I’s
turbo/intercooler
This is what I've gathered together that I can install myself for my current budget.
https://www.xtremediesel.com/xtreme-...asket-contents
https://www.dieselpowerproducts.com/...46&cartrecid=0
I'll run this until my next winter layoff. My occupation is generally "seasonal" (carpenter/structural welder). Once that starts, I'll have plenty of time to contemplate trans, injectors, hpop, valve springs, intercooler, etc.
BTW, I'm no longer considering the Banks Power Pack. Advice has been taken.
I'd still love advice on transmission upgrades, though. After looking through everything -- I'm kinda wishing I had purchased a manual instead of an automatic. Things for the auto seem to be more limited (As far my novice brain can tell). No "simple" clutch kits, or things like that. It's either full upgrade/rebuild or gtfo!
on
