Diesel vs. Gas Longevity?
#31
I've owned several of every Powerstroke since 1999. I just got rid of a 2017 6.7L. I've only logged about 3 million miles with mostly diesels, so maybe I'm green, but at this time, and probably forever from here, I too will never own a diesel out of warranty unless the EGR and DPF are pulled off before 10k when new. The oil alone tells the story. Untweaked, your fingers that touch the drain oil stay black for days. Tweaked, you can see through it at 5,000 mikes. My experience, the new emissions have spoiled all the fun. I was fed up driving to run a regeneration out to completion.
I understand you not liking the modern emissions controls. I don't really like them either...they add expense and failure points. I think they have evolved to a point where they are pretty reliable, though. For me, my main concerns are the fuel system and the major expense if you get water in the system, or some other contaminant.
#33
#34
Troverman, I DO think the oil speaks volumes. On my diesels, I sent them in to Blackstone. On my 2013, I never mentioned when I tweaked it, and watched the oil improve over several changes until they asked what I did to get my oil results to improve EVERY change from the first changes up to 30k. After 30k, the results just got better from wear to obviously, dilution. Then, run your fingers through a stock diesel truck and watch your hands stain from the excessive carbon in the oil. Carbon is an abrasive. After a few changes after being tweaked, my hands never were stained again, and the oil substantially more clean at higher miles. Even the detergents available at higher mileage allowed me to go up to 12,500 from 7,500 after tweaking. I still changed every 5,500.
#35
Good for you, smokewagun. From my perspective, oil in a diesel engine gets very black very quickly, regardless of emissions equipment or not. I'd be curious on one thing, though...if you pull your dipstick after the oil has been in the engine for at least a few hundred miles and sniff it...does it smell like diesel exhaust?
#36
Every diesel I have changed the oil in, the oil turns black quickly, that's not a bad thing, that just means the detergents in the oil are doing their job. However an emissions equiped Diesel will have more oil contamination, and dilution, but that can only be tested by an oil analysis not by the color of the oil.
#37
My point is that a DPF and EGR choked diesel truck will produce a worse, and I do mean WORSE, oil sample much quicker than a properly tweaked truck. The carbon level is much higher and much sooner than a tweaked truck.
I thought I read on here you had history with diesel various diesel trucks, but I may have you confused with another member. If I do, I apologize. If you change your own oil and have run both stock and tweaked trucks, you should understand what I'm saying. It's not like one gets dirtier sooner, it's just a different product. DPF/EGR trucks produce very black oil that is full of extra abrasive carbon. That's only what I was trying to say. I think excessive carbon = additional abrasion = premature wear and sludge and failure. That's all. You're on point with dirty oil. I just see one more detrimental to engine life than the other.
#39
#40
Trovermsn, I'm not sure if you are trying to silently ridicule me, or not. I agree the oil in a diesel will get dirty quickly. yes, my oil did smell like diesel exhaust. It's a combustion engine. Any combustion engine will have oil resulting in the same type of smell. My current gas rig has oil that smells like gas exhaust.
#41
I don't think gas/diesel makes much difference at all in longevity anymore.I'm intending to keep my next diesel for 12-14 years at most. That's about as long as I kept my V-10 F-250. The trouble isn't in longevity of the mechanical components but rather the electronics. I wouldn't expect a computer to work 20 years without upgrading the motherboard and just about everything else inside the case. Support for software just doesn't seem to ever be kept up for 20+ years.
#42
#43
#44
s lubrication system)
Also, as stated, some engines produce more soot than others during the combustion event. Older per-combustion engines produced more than newer direct injected engines, but when you get new enough to have EGR systems, the soot levels returned back to levels similar to the older pre-chamber engines. The "cleanest" (based on using opacity as the test, which is meaningless) engines are direct injected pre-egr engines (like a 7.3 Powerstroke). My 7.3 Powerstroke oil looks much "less black" than my 89 IDI 7.3.. But that is a meaningless point in judging the oils service life. Many, many fleets are running oil to the point of failure, but even then, its not the soot that causes the failure of the oil.
Oil analysis is the only way to evaluate oils useful life, but it isn't cost effective unless being used to to extend oil drain intervals for large fleets (they don't sample every truck every time). A huge amount of money can be saved by fleets by extending drain intervals to the maximum safe point. For someone with only one (or a few) engines, it is more economical to just change the oil at the recommended intervals established by the manufacturer for THAT ENGINE AND USAGE.
Black oil isn't wearing out your engine unless it has dirt in it.
#45
I would mention that one reason diesels have historically outlasted gas engines is that they have heavier duty internals. This is still true today. If you compare a gas 6.2L Ford to a 6.7L diesel, the gas engine has two long timing chains, variable cam timing, tiny little lifters on the end of the rocker arms, etc. The diesel has a vastly larger and stronger crankshaft, massive lifters which drive two pushrods each and have large roller wheels on the bottom, a gear driven single camshaft which is huge, gear-drive fuel pump, etc. Granted, some of this strength is due to the higher forces imparted on the internals...but realistically it is built much more heavy duty than the gas engine.
