c notch
cheers kiwiguy
Crown vic lowering springs are available from Eaton Detroit and lower it 1.5-2" https://www.eatondetroitspring.com/a...rown-victoria/
or get some coil overs from multiple vendors. https://www.speedwaymotors.com/RideT...ic,338405.html
Rear Options
C Notch Options.
https://www.performanceonline.com/19...-c-notch-kits/
Or go buy some 3/16" flat bar approx 6" wide and get it cut to length or buy a 10' piece and cut to size and shape accordingly and also use it to build boxing plates.
You will also require shorter shocks on the rear once you get your rear axle flipped or spring packs modified.
D
