Sponsored by: Real Truck
H I D light question
Old Sep 15, 2018 | 09:42 AM
big315's Avatar
big315
I had some HID headlights installed and I have a questions. It seems like on the low beams, with the fog lights on, they shine higher than they do when I hit the bright lights. I have had the ballast thing changed and I thought it was fixed, but it is still doing the brights. Anybody have any ideas?
Thanks,
Old Sep 15, 2018 | 10:26 AM
02TB250's Avatar
02TB250
Thanks,
There's a possibility that the harness is pinned backwards. I dont know about the newer trucks but on my 02, the harnesses usually were set up for 9004, it needs 9007, and can be easily switched.
Are these just bulbs in the factory halogen housing?
Old Sep 15, 2018 | 11:31 AM
jav_eee's Avatar
jav_eee
More than likely you had them installed in the factory housings that were NOT designed for that type of bulb. The focal point of the reflector was made with the halogen bulb specs. Your new bulbs are either too long (most likely) or too short and what you're experiencing is a result of that. You're seeing that annoying glare you get when you pass another vehicle with HIDs installed in housings that weren't made for them. I'm sure you've come across a couple. It's annoying and unsafe. To get the full benefit you need to put those bulbs behind projector housings that will "aim" the light.
Old Sep 15, 2018 | 12:18 PM
big315's Avatar
big315
I had them installed in the factory housings. Where can I get the updated housings you mentioned? The truck is a 2007 F-350.
Thanks,
Old Sep 15, 2018 | 12:32 PM
02TB250's Avatar
02TB250
Thanks,
you either buy an ebay special. Or you have to have them made like I did.
there are a few companies that will make them and ship them or you can have your own modified.
Old Sep 15, 2018 | 12:36 PM
big315's Avatar
big315
SO, are those the halo light kits? They look great and I bet they work like a charm.
Old Sep 15, 2018 | 12:40 PM
02TB250's Avatar
02TB250
I had halos. They stopped working so i disconnected them, but it's a kit from theretrofitsouce.com mine are mini H1s
Old Sep 15, 2018 | 01:15 PM
big315's Avatar
big315
OK. I went the the website and will ask them what to use. I don't want the Halo's, Just for the HID's to work better. I am on small roads early AM and late at night. Don't want to hit a deer if I can see one.
Thanks,
Old Sep 15, 2018 | 03:31 PM
02TB250's Avatar
02TB250
Thanks,
another alternative might be LED lighting either Cubes or bars.
Old Sep 15, 2018 | 05:28 PM
Djosbun's Avatar
Djosbun
Factory housings are meant for factory-style bulbs. There is zero chance they will give you the look of factory HID lights. The reflectors are engineered for the bulbs they are designed for.
— Dave
Old Sep 15, 2018 | 10:31 PM
big315's Avatar
big315
So, what do you think I should get. Buy the aftermarket housings to use with the HID bulbs?
Old Sep 15, 2018 | 10:34 PM
Evan_P's Avatar
Evan_P
You can have the same output as the HID projector setups the OEM makes, you just have to retrofit in projectors into your housing. It's not for a Superduty, but in my signature is a link to projector retrofitting. It will give you an idea of what is involved.
Old Sep 16, 2018 | 09:01 AM
Jose Miranda's Avatar
Jose Miranda
If by “bright lights” you mean the high beams then I know for my 2013 when I turn on my high beams it automatically turns off my fog lights. I dont know if that’s the case for older models though. I’ve noticed when i turn on fog lights the ground gets brighter. This may be why you think the fog + low beam is brighter than your high beams.
timmyboy76
Jan 19, 2018 01:23 PM
Phantomwraith
2015 - 2020 F150
Jul 27, 2015 02:29 PM
ExcursionUSA
Oct 29, 2011 06:38 PM
fireftnford
2004 - 2008 F150
Jul 31, 2006 09:38 PM
OfficerLow
Jun 18, 2002 04:17 PM
