Sponsored by: Real Truck
Coolant Block Drain?
Old Sep 15, 2018 | 01:36 AM
SMarquez's Avatar
SMarquez
Is there one for the V10 engine? Every thing I see on Youtube shows the radiator drain and flush a couple times but that will still leave water in the block. I'd like to get it all out before I refill. This is on a 2000 V10 if it matters.
Old Sep 15, 2018 | 06:42 AM
02TB250's Avatar
02TB250
to flush the block you could just put water down the upper hose until it comes out clear from the bottom. Or if you're going to go through all that change the thermostat and flush water through the thermostat housing.
you could use this as a guide, should be essentially the same. 2004 F250 5.4L Coolant Flush
Old Sep 24, 2018 | 06:25 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Yes each head has a plug that a 3/8" ratchet fits into
Old Sep 27, 2018 | 02:42 PM
CalEx4x4's Avatar
CalEx4x4
6.8L Block coolant drains
Have never seen a coolant drain in the heads, but here are photos of the block drains.
Have a drain **** in the drivers side. Easier to get to.
Passenger side is harder to get to. Someday . . .
Old Sep 27, 2018 | 05:36 PM
SuperDutyScaler
Someone must have added that brass drain on the drivers side, ford only installs them plugs from the factory. I actually like that I'm gonna buy one now and add it when I flush mine in the next week or so
Metz22
Nov 19, 2015 07:13 AM
papp
Modular V10 (6.8l)
Apr 22, 2011 06:29 PM
ronsonmax
Mar 16, 2010 07:39 PM
pawpaw
1983 - 2012 Ranger & B-Series
Jul 27, 2005 10:59 AM
dallas01
Modular V10 (6.8l)
Mar 31, 2003 07:06 PM
