heater blower
Old Sep 24, 2003 | 11:01 AM
Ds7776's Avatar
Ds7776
heater blower
i have my 77 f150 4x4 that is getting a 460 but im not sure if the heater blower (the odd shaped thingy in the passenger side of the motor bay) will give it enuf room ive seen some of the trucks here that dont have this blower housing do i need to take it of and if so how?also i have an oil pan from an 88 f250 4x4 will this werk in my truck?
Old Sep 24, 2003 | 11:46 AM
LxMan1's Avatar
LxMan1
heater blower
Usually the trucks that do not have the big blower assembly, also do not have A/C. The bigger unit holds the evaporator and heater core in the A/C equipt trucks, the heater core in the non-A/C is inside the heater box under the dash.
I am not sure on the oil pan, I know that the 2 wheel drives will not enterchange.
Jimmy
Old Sep 24, 2003 | 03:36 PM
Ds7776's Avatar
Ds7776
heater blower
but do i need to get rid of this housing to put a 460 in, i do plan on using new valve covers that look taller than the factory ones. i hope not cause im from the north ;-)
Old Sep 24, 2003 | 06:23 PM
Torque1st's Avatar
Torque1st
Posting Legend
heater blower
You may have to change to the factory heater only setup since you have a 460 with tall covers. Converting is a bear from what I have heard.
Old Sep 24, 2003 | 11:23 PM
grapegravy's Avatar
grapegravy
heater blower
A bear,, true, Torque,, but not impossible,, Bwahahaha It's getting it all sealed properly afterwards that is the real trick,,, lots and lots of tape
Old Sep 26, 2003 | 02:45 PM
plowpusher's Avatar
plowpusher
they put 460 in 2wd AC equiped trucks of this vintage should fit on yours don't know abuot tall valve covers though
Old Sep 26, 2003 | 03:36 PM
grapegravy's Avatar
grapegravy
What year 460? You can always get the shorter valve covers if it's a problem. The oilpan will depend on the motor you are getting, gotta run the numbers
