Ordered the V C Spring swap items
Old Sep 12, 2018 | 04:02 PM
Squirrel13's Avatar
Squirrel13
Just got of the phone with Junior. After determining my intended uses he suggested New V and C code springs and 4 Bilstein shocks. Will ship out tomorrow!!!!!
Old Sep 12, 2018 | 05:49 PM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
Front bump stops, the Dorman 523-085 will work fine.
because of the added spring height they will not make contact nearly as often as with the stock springs but I would still stick with rubber, polyurethane front stops on the Ex are a bad idea.
Back to the block you choose..... I was trying to sort out if you are stacking blocks or adding a tapered block.
If you end up with a driveline vibration just known ahead of time it is from the block changing your pinion angle.
Old Sep 12, 2018 | 05:56 PM
Squirrel13's Avatar
Squirrel13
Junior said with the C i just reuse the oem block. Rear should land 3/4-1” taller than the front when loaded should be perfect
Old Sep 12, 2018 | 06:01 PM
pirate4x4_camo
FTE Remembers
Perfect, that clears up the block issue.
Old Sep 13, 2018 | 07:00 AM
msuser92's Avatar
msuser92
When those C codes show up, I would like to see some pics. I have some C codes from a 250/350 that I will be using and I need to take off the top leaf because of rear A/C, IIRC. I want to see how their packs look.
Old Sep 13, 2018 | 08:37 AM
Squirrel13's Avatar
Squirrel13
They should ship out freight today. Ill will post ip some pics when the show up
Old Sep 15, 2018 | 01:21 AM
rdinmv's Avatar
rdinmv
I got the v and c a couple weeks ago, JR says he sells a special c made by a different MFG when he sets up excursions, mine aren't installed yet but heres a pic.....
Old Sep 15, 2018 | 07:03 AM
msuser92's Avatar
msuser92
Stewart,
Could the title of this thread be changed from "V B spring" to "V C spring"? To better reflect what the OP ended up getting/installing.
Thanks
Also, I couldn't figure out how to tag you
Old Sep 15, 2018 | 01:23 PM
Stewart_H's Avatar
Stewart_H
Stewart,
I do agree, but since the OP is still within his 30 day edit window where he can alter his original post as he want's, he can edit the thread title if he so chooses.
Here ya go, like this: [ utag ] Name of User Here [ / utag ] But remove all spaces first, so the coding can take affect. It will look like this: @msuser92
Stewart
Old Sep 24, 2018 | 11:34 AM
Squirrel13's Avatar
Squirrel13
I updated the thread title guys.
Old Nov 14, 2018 | 01:16 PM
90limited's Avatar
90limited
Soooooo... Did you get them installed?
Old Nov 14, 2018 | 01:22 PM
Squirrel13's Avatar
Squirrel13
Old Nov 14, 2018 | 02:18 PM
  #28
90limited's Avatar
90limited
wow. that seems to have given you quite a lift or am I seeing things.
Old Nov 14, 2018 | 03:41 PM
  #29
Squirrel13's Avatar
Squirrel13
Front drivers side
hub to fender 22-5/8 after 25.5
front passenger side
floor to fender 37.25 after 39 7/8
Rear Drivers side
hub to fender 24 after 26
Rear passengers side
hub to fender 24.25 to 26
Old Nov 14, 2018 | 04:25 PM
  #30
Lance Helmert's Avatar
Lance Helmert
Stewart, would you enlighten us on the caster issue you mentioned please.
