compression?
Old Sep 12, 2018 | 09:11 AM
PhilH.'s Avatar
PhilH.
Trailering
compression?
I know compression can cause misfires and loss of power. In particular in my 2005 F-150, I get constant misfire when cold (open loop). It also always hesitates on heavy acceleration. Once it warms up (closed loop), the misfire clears up and runs pretty smooth. It does feel like I'm losing power somewhere.
Replaced plugs, coils, injectors, MAF, and fuel filter.
The ONLY codes I get are 0304/0308 with rare 0300.
Can this be a compression issue?
I'm even considering timing components.
Old Sep 13, 2018 | 02:19 AM
redfishtd's Avatar
redfishtd
you don't have timing fail codes
You may need to look at cats . Maybe plugged . Notice cyl 4 and 8 misfire both nearest cats rear of engine maybe back pressure .
Old Sep 13, 2018 | 05:58 AM
PhilH.'s Avatar
PhilH.
Trailering
Thanks! I had considered the CATS, but was unsure. The only reason I haven't pulled the O2 sensors to test for back pressure was lack of the correct tool. I have the O2 sensor removal wrench now. I'll pull them and see what it does.
BlueOx460
May 18, 2018 01:10 PM
ItsAndy
Mar 18, 2016 04:26 PM
Mike5p0
1983 - 2012 Ranger & B-Series
Mar 2, 2014 10:12 AM
cnichols
1997 - 2003 F150
Apr 15, 2012 02:35 PM
dani9678
Modular V8 (4.6L, 5.4L)
Oct 12, 2010 12:06 PM
