Sponsored by: Real Truck
2005 6.0
Old Sep 9, 2018 | 11:49 PM
Dieselbro0813's Avatar
Dieselbro0813
I have a 6.0 bulletproofed with egr delete. I got up Saturday a moved my truck to cut grass. When I was done I went to move it back and when I put it in drive it would not move. It revved and the rpms climbed but no movement. Tried reverse, high and low gear and still nothing. I did see white smoke come out the back as I revved it but it went away after about 3-4 revs. I pulled codes from my livewire and I got 3 different codes. p0110 which was IAT sensor and it checked out good. P0108 which was for my MAP sensor and baro sensor. MAP checked out okay but I cant find the barometric sensor and nothing online has given me info on really. And lastly P0100 for mass and volume airflow sensor. How should I go about fixing my issue if anybody can help me here? Thanks in advance!
Old Sep 10, 2018 | 01:08 PM
kd0axs's Avatar
kd0axs
If the engine revs and the truck doesn't move, then you most likely have a transmission problem. Have you checked the transmission fluid?
Old Sep 10, 2018 | 11:05 PM
burnthelight88's Avatar
burnthelight88
Yeah, none of those codes should equate to no movement, definitely sounds like a tranny problem. Did you try and see if reverse worked? Try a few different gears and see if anything happens. I'd be wondering if your shift cable is fouled up.
dmonell
Oct 10, 2013 11:42 AM
lakewood
Apr 25, 2013 09:59 AM
monstermadness
26
Jun 24, 2011 10:05 PM
JetBlackBronco
1978 - 1996 Big Bronco
Feb 16, 2007 02:59 PM
armantanzarian
1983 - 2012 Ranger & B-Series
May 5, 2006 09:16 AM
