To Circuitboardmedics, got the pdf but I see no pictures on your post. However, testing while cluster is acting is basically impossible since it happens so randomly. After monitoring voltage, did not see any spikes. The voltage stays at 13.6-13.8 with cluster power on or off. I still believe that what ever the cause is, humidity is aggravating the issue and cluster power is stabilizing in low or no humidity. How much do you charge for a rebuilt cluster? The back light from 0 to 30 m/hr on the speedometer is also dead. My truck is a basic, manual transmission, crank windows, manual door lock... air is the only "luxury". 2007 F350 extended cab, 8ft box. I can attach a picture tomorrow if needed.
Quince,
I re-uploaded the plug disassembly pictures in pdf format. Here is the link with our prices for rebuilding your 2007 F350 cluster. Our rebuild includes the back lighting with standard bulbs, but there is an option to upgrade to LEDs. You will also see an option to purchase a cluster as an exchange and return your old cluster as a core afterwards, which means you won't have any downtime with the truck during the process. https://circuitboardmedics.com/ford-...luster-repair/
Let me know if you have any other questions, or feel free to call us at 800-547-2049.
We do have those in stock. Feel free to give us a call at 800-547-2049 or place an order through the website. If you were to order it today and get all of your information to us by 3pm EST, then you could have it as early as tomorrow if you choose overnight shipping. We could easily have a cluster to you by Oct 3rd. Just let us know how we can help you, and we will get you taken care of.
