When I need the heat on and hit "Auto" with the temp as high as it can go why does the "AC" light illuminate on the display? Is something messed up or is it just doing its thing?
Nope...
believe it or not the a/c is on with the heat as well to keep the humidity down !
Sounds strange, but true...
used to work at a consulting engineering firm and found out MOST buildings run on chillers that they add heat to for regulating the temps...
And some of the people I've worked around NEED the a/c to keep the odors to a minmum !
